2002 polaris 700 sportsman no start nightmare
Hey guys I am having quite the headache with a project 2002 polaris sportsman 700 twin.
First off I bought the machine at an estate sale (an older gentleman who passed away) the machine only has 300 miles on it. First thing I noticed it was missing the carburetor. Everything else seemed fine. So I lurked eBay for a while and found a used carb off a (supposedly) running machine. Put it on, no start. Checked for spark, no spark. Well it would give one strong spark the first time the machine turned over but nothing after that.
So after some research I came to the conclusion that I needed a new pulse coil and new CDI. (rmstator) Apparently many 2002 machines were plagued with this issue. So I got everything wired up and checked it for spark. Strong spark on both cylinders. Turn the key the machine fired almost instantly and then died after about 5 seconds. Seemed like it ran out of fuel, sprayed starting fluid in the cylinder got it to fire a couple more times then it would die again.
Fuel is coming out strong from the inline fuel filter. I cleaned the fuel pump and inspected the diaphragms previously anyway. Then I noticed a bunch of the wires coming from the ignition plug-in were melted from a short. I rewired all the wires and still no start.
The last thing I noticed was when I cranked the machine over I have a slow drip from the drain nipple on the bottom of the carb. Seems like the screw was tightened right down at one point and damaged something because I can't get the drip to stop.
Now I'm not totally convinced that this drip would prevent the bike from starting but I'm lost as to what else the problem could be. Looking for advice
I'll probably go out to the shop tomorrow and pour a bit if fuel down into the cylinder and see if I can get the bike to fire again.
That's why I recommend the Polaris 2202602 Kokusan ignition kit that changes everything from the flywheel,stator cdi,regulator and wiring jumpers.Completely eliminates any Ducati related part.Costs a little less than 500 bucks at Partzilla,maybe cheaper if you check around.On the carb may not be the drain screw but the float level may be off allowing fuel past the overflow tube. Carb bowl drain screw and overflow tube both tie into the nipple under the carb bowl.
RM stator kits use the Ducati lighting coil for an ignition source and the lighting coil can fail also! Have had several of them do this,before the replacement Kokusan kits even came out.Any electrical part with Ducati on it is junk!
In the grand scheme of things I probably should have bought the polaris brand upgrade kit. But I paid 500 for the entire machine, and didn't exactly want to spend 500 more on an ignition upgrade.
Regardless though, I have a strong spark so I figure the machine should start.
I know it seems like a lot of money considering your initial investment but if you are having any sort of ignition/electrical issues, you will save yourself a lot of time and grief to just change the entire ignition. Nothing worse than being deep down a trail somewhere and becoming dead in the water. You may replace that one part just to have it fail or a different component fail and you will spend more $ in the long run. it takes some time to get it installed but I did mine myself and I certainly consider myself an amateur. There are a few good videos and the instructions that come with it aren't too bad.
whitty
67
02-24-2021 02:52 PM
Dakosk
06-06-2015 05:37 PM
