Polaris Back fire
Old 01-21-2010, 01:49 PM
abcracing's Avatar
Default Polaris Back fire
93' polaris trailblazer- was running great but now it backfires LOUD, especially backing off the throttle. Will alaways start on the first pull but when I give it the gas it dies outthen tends to clear up for a while. The tank is venting properly. Any ideas? Thanks Tim
Old 01-21-2010, 02:16 PM
TLC's Avatar
TLC
TLC is offline
I would clean the carb first off.
Old 01-21-2010, 02:33 PM
scootergptx's Avatar
Supersock
Hired Gun!
Any cracks in the carb boot? Exhaust leak maybe?
Old 01-21-2010, 08:21 PM
fishycliff's Avatar
my 600 did the same thing had water in gas put additive in it cleared up
Old 01-22-2010, 05:17 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like a lean condtion. check the spark plug to see if it's white. also might be water, but most likely wouldn't run good at all. does it idle high? wondering if maybe it has an air leak? a couple of things to check out and it wouldn't hurt to clean carb if you think it's dirty or replace gas if bad. imo
Old 01-22-2010, 08:22 AM
abcracing's Avatar
I cleaned the carb,still back fires, will change the gasoline next thanks
Old 01-22-2010, 08:31 AM
TLC's Avatar
TLC
TLC is offline
If thats the case try the stuff called "Seafoam" it can do wounders.
Old 10-02-2015, 01:04 PM
emmette79's Avatar
I have trailblazer 97 and it backfires through the air box starts idles fine but when warms up after riding backfires through air box I can figure it out..sometimes won't start back up after it starts doing this..
Old 10-02-2015, 02:30 PM
Not necessary to post twice in the regular section and expert section. Someone will find you.https://atvconnection.com/forums/pol...cate-post.html
MikeyBoyesq
11-27-2020 02:44 PM
buckshit
09-24-2015 08:49 PM
02Chevrolet
1) Engine problems..
06-23-2015 12:12 AM
Steven Bandemer
05-27-2015 07:39 PM
SOLOLUCKY
05-25-2015 05:25 AM
Quick Reply: Polaris Back fire
