2005 Suzuki Eiger Quadrunner question
Old 01-20-2012, 12:15 PM
ramitt3401's Avatar
Default 2005 Suzuki Eiger Quadrunner question
I have a 2005 Suzuki Eiger Quadrunner. I can start it on full choke but as soon as I move the choke lever or give it a little throtle it will stall. It will run on full choke without stalling untill I do one of the above. Any help would be greatly appreciated.
Thank you, Rick
Old 01-20-2012, 12:54 PM
woodsidewarrior's Avatar
It sounds like the fuel has sat in the carb for some time and clogged the jets. A very good carb cleaning should solve your problem . Today's fuel can start to cause you trouble in as little as a couple weeks sitting in your atv without any sta bil in it
Old 01-21-2012, 11:22 AM
treveiger's Avatar
Id clean the carb. Mines been kinda a pain to. I have a 05 eiger also. I'm going to take mine off today for a cleaning/rejetting.
Old 01-22-2012, 12:02 AM
treveiger's Avatar
After I pulled mine out an looked at the pilot jet I could see it was clogged so I sprayed some air through it to clean it out. My carb looks pretty clean now.
Old 01-25-2012, 11:47 AM
Back40's Avatar
Agree with cleaning the carb. I found my idle mixture screw was not opened enough. The idle improved after adjusting out 2 full turns.
Keihin 32CVK Disassembly
Old 01-30-2012, 01:25 PM
treveiger's Avatar
I have my carb back in and its running much better. So I'd suggest doing this.
Old 02-04-2012, 09:12 AM
RonV's Avatar
Thank you, Rick
Sounds like your main jet is clogged. Agree that your carb needs a good cleaning. Remove it, take the bowl off, pull all the jets and spray carb cleaner thru them until they are clear.
txpedsrt1
02-03-2017 08:07 PM
Bulgin88
07-30-2015 05:20 PM
baysport
07-23-2015 11:37 AM
tporath
07-11-2015 12:31 PM
bikedad3
07-02-2015 02:15 AM
Quick Reply: 2005 Suzuki Eiger Quadrunner question
