Barking auto clutch
Barking auto clutch
2005 Suzuki Eiger auto. 500 miles. Last 2 outings it has happened each time. After stopping real fast then hitting the gas the clutch slips and makes a bark sound as the belt slips, then catches. I think the clutch just didn't reset to the idle position? Doesn't seam like a big deal right now, should I go through the bother of pulling it apart?
I have the same issue with my 2012 King Quad 750. I have asked the mechanics at the dealership I work for and they say it is a Suzuki thing. I have around 1500 miles on mine. One of my co-workers has a 2005 King Quad 700 and he put a EPI clutch kit in his machine and it still makes that noise.
I service Suzukis for a living, and when they start grabbing on take off, we fit a new belt, this seems to cure it, but it is extremely rare that we get this problem and I have never had one that made noises. With so few miles in 10 years your belt may have "set" to an odd shape while laid up.
The driven clutch doesn't get a chance to return to "idle" and the belt gets pinched...yet the drive clutch opens up like normal. So when you re-aply throttle you have a loose belt until the driven rotates slightly...then it goes tight again with a jerk and usually a squawk.
I had a 2000 Kodiak that would do this as well.
Next time you stop quickly, just throw it in neutral and rev it for a second to reset it.
I have seen a video documenting this, but darned if i can find it now...
