2005 Kodiak 450 issue
Both hand warmers and winch are accessories, so their electrics are as good as the person who fitted them. They should be on separate in line fuses, and most are wired via the accessory fuse in the bikes fuse box (if it has one) to stop them being left on with the ignition switched off. I work on very few bikes with winches, most farmers don't feel the need for one, as they know where to avoid on their own land, and can pull it out with the tractor if they need to. I do fit a lot of heated grips, and the grips themselves rarely last more than one year. If the warning light (if fitted) on the switch is on, and the grips don't work, suspect the heater elements in the grips. Check with a voltmeter or test lamp, if power is getting to the connector that each grip plugs into.
Heat demon hand warmers yamaha kodiak 400
Hey I did some inspecting of what the problem could be and it is a short in the hand warmers some where do you have and idea of where it could be, they are heat demons when I unplugged the circuit or wires the whinch worked again but then plugged the hand warmers in again and they were not even on yet and it blew got it to work with the whinch off and then turned it on and it blew anouther fuses?
Heat demon hand warmers yamaha kodiak 400 fuse
Hey I have a problem with a fuse on my yamaha kodiak 400 4x4 I did some inspecting and found that when I turned on the whinch when the hand warmers were on and it blew the 10A accessories fuse and I was able to get the winch on and then the second I turned on the hand warmers it would blew again, I think there is a short in the hand warmers I would hate to replace them and find out the same problem is happening. If anyone can tell what is going on it would be greatly appreciated!
RedRancher
10-15-2020 01:45 PM
