Yamoto 150cc Review
Old Dec 2, 2004 | 11:13 AM
  #151
babygrl's Avatar
Default Yamoto 150cc Review
k so i will look into it more. thanks for ur reply
where are those loose bolts???
Old Dec 2, 2004 | 11:26 AM
  #152
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Somebody ask for me? [img]i/expressions/face-icon-small-happy.gif[/img]
Think you are referring to the throttle restrictor which is simply a screw in the thumb throttle.
Old Dec 2, 2004 | 11:32 AM
  #153
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Almost all of the bolt's will loosen, mostly it is the smaller bolt's, all bolt's with a 8-10mm hex head on them and also any phillips head screw's.
Old Dec 2, 2004 | 11:44 AM
  #154
Raptorlegs's Avatar
T Rex Rider
I gotta learn not to skim. He's right. You'll need to have someone check all bolts and tighten if necessary. I'd repeat the process after the frist few runs too.
Old Dec 2, 2004 | 04:36 PM
  #155
KTM Patrol
Former Chinese POW!
If you take them out and use blue loctite ( # 242) you will not have to check them again. I loctite most bolt's on all my toy's, not just my chinese one.
Old Dec 3, 2004 | 12:33 AM
  #156
iwantaquad4xmas's Avatar
k if i didnt tighten those bolts would they come loose? and fall off? i want to get it and start riding it right when i get it with out doing any thing to it.
Old Dec 3, 2004 | 09:11 AM
  #157
KTM Patrol
Former Chinese POW!
Originally posted by: iwantaquad4xmas
k if i didnt tighten those bolts would they come loose? Yes they will
and fall off? Yes they will.
Then I would suggest you spend twice the money and buy a Japanese quad.
Old Dec 3, 2004 | 09:27 PM
  #158
k i really dont want to spend that much money on one so i will probally just tighten all the bolts when i get it. thanx!!! Do u really think the yamoto is worth the money????
Old Dec 4, 2004 | 05:20 AM
  #159
Poohbear's Avatar
MANDRAKE and MYWIFESQUAD - Have you guys had any problems with your throttle?? My sons sticks alot, by that I mean it doesn't want to return when he lets go of the throttle. Do you think it is internal(throttle hausing or cable) or is it the carb???
Old Dec 4, 2004 | 10:09 AM
  #160
KTM Patrol
Former Chinese POW!
No problem's with that here. Having had the carb apart on my wifes quad a couple times I would think it is the cable. I would look at the throttle mechanism on the handle bar and also check how it is routed, no sharp bend's etc... This is something to figure out soon, A stuck throttle is scary.
