Yamoto 150cc Review
Old Feb 8, 2005 | 06:28 PM
  #251
ToddsYamoto150's Avatar
Default Yamoto 150cc Review
What exactly is the power/torque gain after changing to the K&N on these Yamoto 150's? I need to do this. Not actual HP #'s. How does the machine feel compared to stock? Thanks.
Old Feb 8, 2005 | 06:38 PM
  #252
Kell's Avatar
Whether it gives you power or not you need to do it for the better filtration.
kell
Old Feb 9, 2005 | 11:43 AM
  #253
kingdave's Avatar
I ordered the K&N and haven't gotten it yet. I'll let you know after I get it installed and take it for a spin.
Old Feb 9, 2005 | 01:41 PM
  #254
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Just finished up installing the UNI filter on my wifes quad, I did not end up using the airbox. I wanted to mount it up higher to keep from kinking the intake hose. If I did that I would never get to the screws on the side of thr airbox without removing the front plastic and the gas tank. It is tucked up pretty high and should not be a problem with the way my wife rides.
Old Feb 9, 2005 | 01:45 PM
  #255
kingdave's Avatar
So basically, it's just an open air filter? That is probably what I will do when I get the K&N.
Old Feb 9, 2005 | 02:15 PM
  #256
KTM Patrol
Former Chinese POW!
Yes it is, I have kept the old airbox just in case I decide to try abd make it fit. Most likely will leave it as it is, it is real easy to service now.
Old Feb 10, 2005 | 06:53 PM
  #257
kingdave's Avatar
Has anyone had a problem with the valve set starter on the carb? Its the part that has 2 wires plugged into it. I've been having choke problems and think this part is the cause. I noticed when I turn on the key it gets hot. I've been having trouble starting the quad in cold weather and think this may be the cause. Thanks
Old Feb 10, 2005 | 08:43 PM
  #258
KTM Patrol
Former Chinese POW!
kingdave, there has been a lot of talk on this in HERE
Good info and options.
Old Feb 21, 2005 | 11:18 AM
  #259
kingdave's Avatar
Thanks for the info.
I just got the K & N filter intstalled. I did notice a slight gain in throttle response/acceleration. Not really a gain in top end speed, but you definitely can tell the difference. Also sounds a little better. Still won't start when it's cold but it was 70 degrees here on Sunday and it fired right up.
Old Feb 21, 2005 | 07:16 PM
  #260
KTM Patrol
Former Chinese POW!
Definitely sounds better hearing the air going in the carb. Throatier for sure.
