Yamoto 150cc Review
Old Jan 19, 2006 | 03:33 PM
  #521
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Default Yamoto 150cc Review
Originally posted by: basseyl
I'm way behind. This link is expired, I can't see the fix. This is definitely my problem. Could you type what to do. Thanks and good job.
What is the link to? And welcome to the forum basseyl.
Old Jan 19, 2006 | 03:49 PM
  #522
basseyl's Avatar
I'm guessing it was a fix for the non-working choke. Something about drilling and tapping the housing maybe.
Old Jan 19, 2006 | 03:52 PM
  #523
KTM Patrol
Former Chinese POW!
I sort of remember that one. It only worked for some, not all from what I remember.
Old Jan 19, 2006 | 03:56 PM
  #524
basseyl's Avatar
I've also got a bent sproket shaft from the tranny (about 3/4 of an inch) thats going to have to be replaced. Anyone have this problem. I suspect #1 son managed this when the rear sprocket sheared the bolts. It appears to me that the relation of that drive sprocket thru the centerline of the swingarm to the rear sprocket requires the chain to remain very loose. I bet if I remove the rear shock and move the swingarm to its longest position, that the chain will then be tight and thats what sheared the bolts. Think this thing needs a chain tensioner.
Old Jan 19, 2006 | 03:57 PM
  #525
KTM Patrol
Former Chinese POW!
What year yamoto 150 do you have?
Old Jan 19, 2006 | 04:21 PM
  #526
basseyl's Avatar
Thanks for the reply. Purchased Mar 05 but after reading thru all this, it may be an 04. (no reverse, single a-arms)
Old Jan 19, 2006 | 05:07 PM
  #527
KTM Patrol
Former Chinese POW!
Your welcome, i would say its a 04 also. have you ever cleaned the carb? And what problems are you having?
Old Jan 19, 2006 | 05:28 PM
  #528
basseyl's Avatar
This thing probably has truly 25 hours on it. The prob is mainly cold starting or lack thereof. I've cut off and welded in new angle iron for the pegs. The motor seems strong except for the cold starting. I've picked up from this forum ideas for k & n filter. I posted to an earlier msg that an 04 Dinli 90 front bumper will bolt on as I had the same prob with bottoming. The chain jumps off due to slack, but am hesitant to tighten as I think it gets tight during swingarm travel and bent the drive shaft. Other than that the kid loves it and just wants seat time.
Old Jan 19, 2006 | 05:36 PM
  #529
KTM Patrol
Former Chinese POW!
i have heard of some here who put a space heater in front of the quad to warm it up before starting. As for the chain I dont run much slack at all and i put a shock on it that actually has some travel. Do the sprocket look aligned? Well did they look aligned before the shaft bent?
Old Jan 19, 2006 | 06:09 PM
  #530
basseyl's Avatar
Glad you asked that. Actually, the drive shaft sprocket looks slightly inbound from the axle sprocket. It doesn't appear to have affected any wear on either sprocket, but very few hours.
