Yamoto 150cc Review
Old Jan 16, 2006 | 01:32 PM
  #511
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Default Yamoto 150cc Review
Originally posted by: kingdave
Has anyone replaced the chain? Mine seems to be stretched and I am unable to tighten it any further. I would like to just buy a smaller chain. Any info would help. Thanks.
Im not even close to replacing the chain on my wifes Yamoto. I always figured it was a 520 chain but have never verified it.
Old Jan 16, 2006 | 02:22 PM
  #512
tintsem's Avatar
Speaking of chains. I need to find some sort of chain guard for the 150. The sand causes the chain to bind. I remove the factory one because it sat too low. Any ideas would be appreciated.
Old Jan 16, 2006 | 02:29 PM
  #513
KTM Patrol
Former Chinese POW!
Have you seen the guard I made out of alum angle stock? Its in my pics.
Old Jan 18, 2006 | 03:10 PM
  #514
worley4's Avatar
In response to 2manytoys: The frame cracked at the lower motor mount and pulled a big "chunk" right out of the frame. I disassembled it to check the rest of it and found that several welds (or right around the weld) are also cracked. These frames are like iron and very brittle. I prepped and welded the motor mount back into place, and it now has a few more hours on it, but it's already beginning to crack again around the weld. As for the choke, Patriots fix didnt help so I tossed it out. I took the elec choke completely apart, removed all the springs, drilled, tapped, bonded it all together, so I could manually move the plunger, I used safety-wire to move it up and down, with hopes to come up with some kind of lever. Dirtforashirt is right, its kinda hard to get a hand in there to work it. I am also experimenting with spark plugs. I cant seem to get it just right, if anyone has successfully crossed the original plug with another, let me know. thanks. MAN I HATE THIS QUAD!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 18, 2006 | 03:23 PM
  #515
KTM Patrol
Former Chinese POW!
NGK C7HSA
Old Jan 18, 2006 | 03:40 PM
  #516
worley4's Avatar
NGK C7HSA
thanks. that was quick.
Old Jan 18, 2006 | 03:42 PM
  #517
KTM Patrol
Former Chinese POW!
NGK C7HSA
Your welcome. Im at work and dont have enough to do. [img]i/expressions/face-icon-small-smile.gif[/img] Your lucky I wasnt at home! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 18, 2006 | 04:11 PM
  #518
kingdave's Avatar
I run an Autolite plug:
Autolite 4194
also...
AC DELCO S102F and the NGK Iridium plug is CR7HIX.
Old Jan 18, 2006 | 05:01 PM
  #519
KTM Patrol
Former Chinese POW!
Autolite 4194
Thanks for that info kingdave. I run autolite's in the rest of my toys and always wanted on for the Yamoto. Im going to go get one this week.
Old Jan 19, 2006 | 03:12 PM
  #520
basseyl's Avatar
I'm way behind. This link is expired, I can't see the fix. This is definitely my problem. Could you type what to do. Thanks and good job.
