kazuma 90 panda i think help everything wrong
Old Dec 17, 2011 | 10:46 AM
  #21
jeffiason's Avatar
thanks so much for the advice quad is running great even got signales flashing ..lol.thanks again
Old Dec 17, 2011 | 11:49 AM
  #22
armagh's Avatar
Lynn Edwards is a Wizard with the electrical stuff. He helped me with mine. I was the guy that had all the bad CDIs. New, out of the box, but still they were bad.
Old Dec 17, 2011 | 10:21 PM
  #23
LynnEdwards's Avatar
Electrical Expert
I'm glad it is up and running...
Old Jan 23, 2012 | 04:05 PM
  #24
jawk's Avatar
Talking
Hi all, I have a similar CDI question - the 90cc 2T Panda I have bought has (apparently) got a faulty CDI (see pic below).
IM having trouble locating one identical. Ive found ones that 'look' the same but with slight differences in wire colour.
1. Can I use any old 2 stroke CDI that looks the same (eg. off a PW50 or 80 or similar)?
2. Can the type of box like CDI pictured earlier in the thread be used if wiring set up?
I dont want to let this little black box beat me!
I would greatly appreciate any help you can give.
Cheers and thank you in advance
Gary
Victoria - Oz
Old Jan 24, 2012 | 11:29 PM
  #25
Electrical Expert
[snip picture]
I don't know a lot about two strokes. I do know that the 5 pin 4 stroke CDI pictured in the earlier posts will *not* work on a 2 stroke. See the following two links to see the whole story:
http://forums.atvconnection.com/chin...-90cc-atv.html
http://forums.atvconnection.com/chin...bogs-down.html
If you find a two stroke CDI that looks similar you might give it a try. That's the same advice I gave for the 4 stroke CDI in the links above which turned out to be completlely wrong. But if it were me I would give it a go anyway.
Why do you think the CDI is bad? Have you checked the stator outputs with a meter, changed the spark plug, checked coil continuity, etc?
Old Jan 24, 2012 | 11:41 PM
  #26
jawk's Avatar
Well, I think the CDI is buggered because the fella I bought it from said his friend (who knows about these things) said so...
Hmmm, Im thinking what your probably thinking now - put the CDI back in, check the measurements you've talked about earlier in the post, check ignition switch etc etc etc... Then see for my self!
There doesnt seem to be a kill switch - only the ignition switch.
There is some spurious wiring and a funny looking thingo up the back of the bike that I dont know what they are (ive posted up a pic'); but i'll assume that is for lights or something until i know better.
Cheers and thank you for your reply!
Gary
Old Jan 24, 2012 | 11:47 PM
  #27
jawk's Avatar
...addit,
Theres a CDI for a YB90 (i dont know what that is tho) that even has the same colour wiring for abour $20 AUD - its even in Oz which is a bonus!
Ive sent them a message to see if they can supply wiring details.
Gary
Old Jun 13, 2012 | 06:56 PM
  #28
jawk's Avatar
All fixed now.
Did some more digging and appears that the bike is a Dinli two stroke from about year 2000 (supposedly they make/made Kazuma back then and others).
So I got some diagrams from the web and had a friend diagnose that the stator/generator thingo wasnt working. Got one of those that visually matched off our favourite auction site, and bingo, got spark!
CDI was fine.
So, put a new battery, and spark plug then fuelled it up - but then the fuel ran out as the tank had a split - okay got it welded up and bingo she started and ran after several years in a shed!
Everyone happy!
Thanks for those who gave me feedback to work with
Gary
Victoria - Oz
Old Jun 13, 2012 | 11:25 PM
  #29
Electrical Expert
Thanks for reporting back. It helps to get final closure. It really helps others down the line who have similar problems... .
Old Jun 18, 2012 | 11:17 PM
  #30
jawk's Avatar
Just as an aside - Strewth does it go !!
Possibly too quick for its intended riders...
Not sure of fuel mix at present (not using oil injection tank as it leaks), so running 32:1 - bit fuel smoky, so might try a leaner mix with the same oil i use in the enduro bike (KTM250).
bmxatv10
Oct 14, 2022 06:23 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
