Carb issue
Old Jul 25, 2010 | 06:55 PM
cotjjeeper's Avatar
Default Carb issue
Have a new (25 miles) 500 UTV Husang-Massimo (from V-bikes). After running great for the first few weeks, it died, wouldn't start. Took carb off, took apart, cleaned all jets, reinstalled, it runs, but not consistent, and seems real rich, with no top end power, then dies. I am at 5,500 ft alt. A few questions:
1. When I reinstalled the jets, I put in all the way to tight, is there an adjustment for them (3 inside bowl)
2. Where is air/fuel adjustment on PD 36J-C carb?
3. Any thoughts on what I am missing?
Thanks
Old Jul 29, 2010 | 08:59 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum cotjjeeper!
1. No you cant tighten the jets to tight.
2. Most are on the bottom of the carb.
3. Are you still using the Chinese spark plug? do you have a fuel filter on the quad?
Old Jul 29, 2010 | 05:45 PM
cotjjeeper's Avatar
Default Thanks
2. yes still using original spark plug, any suggestions on replacements, and should I replace?
3. Yes, two filters, both clean, getting good strong fuel flow.
THanks
Old Jul 29, 2010 | 06:00 PM
KTM Patrol
Former Chinese POW!
Only seen 2 plugs used in Chinese quads..NGK C7HSA and D8ES Id guess you need a D8ES, but Im not sure..
All of the Chinese spark plugs Ive seen had either a 7 or a 8 on them and were the same physical size as either a C7HSA or a D8ES. The D series of plugs is larger than the C series.
Old Jun 11, 2014 | 05:08 PM
Brodz's Avatar
Default Chinese utv 400cc wont start
Drove the UTV shut it off but will not start back!
You can put your hand over the air inlet on the carb and it will start and run but smokes.
Went thru carb and still wont run.
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
