Throttle issues
Old Nov 21, 2010 | 01:32 AM
rufrydsc2's Avatar
Default Throttle issues
I just got a couple of Peace atvs, a 110 and a 70 for $100 each. The 70 turns over, but doesn't have any spark, I figure I've got to replace the ignition module to fix that, but the 110 starts and runs very nicely. The only problem is if you give the 110 anything more than 1/4 throttle it dies. I don't know anything more about the two atvs as the guy I bought them from didn't speak much english, but I figure they have been sitting for quite a while. Any suggestions would be most appreciated as I'm anxious to get the kids out riding. Thanks yall.
Old Nov 21, 2010 | 09:46 PM
LynnEdwards's Avatar
Electrical Expert
Originally Posted by rufrydsc2
...the 70 turns over, but doesn't have any spark, I figure I've got to replace the ignition module to fix that....
I would do some measurements with a meter before just blindly changing things. There is all your kill switch wiring, the stator trigger signal, the CDI power (whether you CDI runs on high voltage AC from the stator, or DC from the battery), and the ignition coil. All of these things (plus all the wiring between) is involved in making spark. Most of these can be measured. If you need help we can walk you through it. You'll need a meter of course.
How many pins on your CDI?
... but the 110 starts and runs very nicely. The only problem is if you give the 110 anything more than 1/4 throttle it dies.....
Look for recent post by Jaster94. He has some good info, pics, and YouTube links on how to clean your carburetor. That is the first place to start for quads that have sat a while.
Old Nov 21, 2010 | 10:12 PM
rufrydsc2's Avatar
Thanks, I got my meter out and started playing around with checking the wiring the other day. I didn't look to see how many pins the CDI had, but I'll look and let you know. I suspect it might be the kill switch too.
Old Nov 26, 2010 | 08:51 AM
rufrydsc2's Avatar
The CDI has 5 pins. I've checked out pretty much everything on this little atv now. I figured out that the brake interlock switch wasn't working correctly so I bipassed that and now the bike will turn over on the start switch command, but still not getting any spark. Does anyone know what the ohmage should be for the stator? I'll create a diagram today showing what readings I get from the different pins and see if anyone can help me.
Old Nov 26, 2010 | 09:28 AM
rufrydsc2's Avatar
Old Dec 14, 2010 | 04:57 PM
rufrydsc2's Avatar
Ok, so I got the 110cc running after a thorough cleaning of the carb. The only thing now is that it won't idle when warm. When the engine is cold I can adjust the idle up, a bit, but when it warms up the engine dies. I've tried to adjust the needle clip and this did nothing. Any suggestions?
Old Dec 15, 2010 | 10:48 PM
rufrydsc2's Avatar
When given gas the engine runs fine, only when trying to idle does it die.
Old Dec 19, 2010 | 07:24 AM
rufrydsc2's Avatar
Noone knows what might be wrong with this??
skinnyr6
Aug 25, 2023 02:18 AM
GregM
Mar 6, 2018 06:53 AM
skeets44
Jul 17, 2015 01:04 PM
MNatv89
Jul 7, 2015 11:36 AM
