2003 SunL 110cc Just stopped running
Old Nov 7, 2011 | 11:27 AM
SteelersFan7's Avatar
Default 2003 SunL 110cc Just stopped running
my niece's 110cc sunl quit running while she was riding it. The battery was fully charged when we took her out, she was riding for approx. a half hour and as she was riding it just died. We tested the battery with a screw driver touching each terminal and there was a great spark, yet there's no spark coming from the starter solenoid? The start button hasn't worked in a few weeks, she has ridden it about 5 times without the starter button, we were touching the wire connectors to the starter solenoid to get it to crank, now there's nothing, not a spark, or a crank or anything just nothing. can someone tell me what to check before I trash it ?? I have an extra 110cc sunl parts quad with new parts such as cdi box,starter, solenoid, magneto, regulator, coil to spark plug. any help would be greatly appreciated by my little 8 y.o. niece. Thank You !!!!
Old Nov 7, 2011 | 10:58 PM
LynnEdwards's Avatar
Electrical Expert
Take a meter and measure the DC voltage right on the battery terminals while simultaneously jumping across the starter solenoid. What voltage do you measure on the battery while it's under the load from the starter motor?
It should be above 11.5 volts.
I'm wondering if your battery is discharged (your shorting the battery with a screwdriver is not a very definitive test).
You could also jump the quad battery to your car battery with jumper cables. If your quad battery isn't up to the task then jumping it to your car should prove that if the starter spins normally.
Old Nov 9, 2011 | 09:33 AM
Thumbs up
Well thanks for the response and advice but I figured out the problem. While she was riding she somehow lost the ground wire.
Old Nov 9, 2011 | 11:33 PM
Electrical Expert
Awesome
I'm glad you got it running...
tiresharkdbb
Sep 3, 2017 02:06 AM
Dame0927
Oct 29, 2015 10:13 PM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
FWhitt
Jun 13, 2015 02:22 PM
bigmanm
Jun 28, 2000 10:34 PM
