2007 Eton Yukon 150 Starting Issue
Old Apr 28, 2012 | 09:03 PM
thunder quad's Avatar
Default 2007 Eton Yukon 150 Starting Issue
I recently bought a 2007 eton yukon cxl 150 for my daughter. It will start fine when hooked up to a charger. I assumed the battery was dead. After an overnight charge, the battery is holding. When I put the battery back in, and turned the key on, the neutral light came on as I expected. When I hit the starter button I see a spark at the positive terminal of the battery, then i loose all power. If I turn the key off and let it sit for a minute or so, the power will come back when I turn the key back on. But, I get the same thing.
Second question. When I do crank it with the charger, It idles great. But, it pops in the mid range, then levels back out at higher RPM's. Any ideas?
Thanks
Old Apr 29, 2012 | 09:56 AM
Jaster94's Avatar
terminals are tight? what are the volts measured when cranking the starter? sounds like a combination of a couple of items. loose connections and a dying battery.
Old Apr 29, 2012 | 10:27 AM
LynnEdwards's Avatar
Electrical Expert
Jaster94 is spot on. You have a bad connection right where you was that spark. That bad connection gets blown open by the massive starter current - making a spark.
Old Apr 29, 2012 | 08:03 PM
You were both dead on. I cleaned the battery terminals and the cables. It started right up. Thanks for the help. I also cleaned the carb up and it is purring like a kitten. Thanks for the help everyone.
Old Apr 30, 2012 | 07:52 AM
Jaster94's Avatar
i got one of these quads. never ridden it though. i'm putting the transmission back together. hopefully take it out in a couple of days. glad you got your quad going. good luck.
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
jag6510
Jun 15, 2015 05:59 PM
brinkkl2000
Jun 11, 2015 12:46 PM
1000gade
May 27, 2015 12:37 PM
