Wiring Problems/Bypassing Safeguard
Old May 25, 2012 | 03:28 AM
IXBillyXI's Avatar
Originally Posted by LynnEdwards
Does your left handlebar kill switch shut off the engine? Most quads have multiple kill switches which are all wire in parallel. Any on of them can shut off the engine. You ignition switch has a section (one of two or more) that is a kill switch too. When you turn the ignition switch off it shorts two wires together (the kill switch wire and ground), which kills spark and stops the engine.
So the question is: Does any kill switch work, or is it just the kill switch section of your ignition switch that doesn't work?
Just the ignition switch doesn't turn off the engine.
Old May 25, 2012 | 10:22 PM
IXBillyXI's Avatar
One more thing I want to add is something that the ATV is doing weird. When I give it full throttle and get it to top speed the bike sounds likes it's hesitating and causes the bike to vibrate a lot. Anyone know what this might be caused by?
Old May 26, 2012 | 09:21 PM
LynnEdwards's Avatar
Electrical Expert
So the kill switch section of your ignition switch is not working. Did you unplug the remote module? If so that explains it. Unplugging the remote will disable all the remote functions, but there is one added feature: You won't be able to turn off the quad with the ignition switch. You'll have to use the left handlebar kill switch instead.
If you really did unplug the remote, then to restore the ability to kill the engine with the ignition switch can be restored by adding a jumper across two pins on your remote connector. We can explore that route if you desire. But most just get used to using the handlebar kill switch...
toonces
Sep 5, 2015 01:14 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
