New CDI...
Old Jun 13, 2012 | 10:19 PM
cesar110's Avatar
Exclamation New CDI...
Hello,
I got a new gold (6 pin) Casoli DC CDI, my ATV originally was AC ignition powered. I ripped out the old wiring harness (it was showing age) completely and was wondering how to install this CDI...
Here is the Ebay link: New Casoli DC CDI Performance Racing for GY6 150cc 250cc ATV/Go kart/Quad bike | eBay
Old Jun 13, 2012 | 11:46 PM
LynnEdwards's Avatar
Electrical Expert
I'm wondering why you didn't buy an AC powered performance CDI...
I'm especially wondering why you ripped out the entire wiring harness...
What are you going to do to replace it? That's a really big job... Even if you want to eliminate all that "useless stuff" (I hear this a lot) like safety interlocks and lights, there is still the "absolutely required stuff" like starting circuitry, the entire ignition system, the battery charging circuitry, ignition kill ciruitry, and automatic choke wiring (if you have that). That's a lot of wires . Are you sure you're up to this? Lots of people have gone down this route before you. To date *none* have got past the first step where they got the starter motor cranking with a push button. That's just a teeny baby step in the grand scheme of things that you're going to need to tackle...
Old Jun 14, 2012 | 09:21 AM
cesar110's Avatar
I am a master at wring but I just couldn't figure how to put the CDI in... The reason why I bought a DC CDI is because I was making the stator to be pure DC to possibly give more power.
Old Jun 14, 2012 | 11:41 PM
Electrical Expert
So here is how it is wired:
Only change the pin labled AC Ignition Power to read Switched Fused 12 Volts.
I'm wondering about the statement:
This has me confused. Stators are always outputting AC voltage and never DC. It cannot be any other way. To generate a voltage in a coil of wire you need to have a moving magnetic field, and a moving magnetic field generates a moving voltage (i.e. AC voltage). That's just the way the physics works.
To convert to DC you need to take the AC output from the stator and rectify it with diodes (which only let current pass one way) into DC. It is also conceivably possible to rectify it in other ways - like the old "generators" in cars back in the early nineteen sixties. They used mechanical rectifiers (they called them commutators) but they were rectifiers none the less. ANd they faded out of existance back then because it was a poorer performer compared to alternators using diodes fro a rectifier.
Old Jun 15, 2012 | 01:18 AM
cesar110's Avatar
I'm wondering about the statement: This has me confused. Stators are always outputting AC voltage and never DC. It cannot be any other way. To generate a voltage in a coil of wire you need to have a moving magnetic field, and a moving magnetic field generates a moving voltage (i.e. AC voltage). That's just the way the physics works.
Whoa! Calm down mighty LynnEdwards! Of course stators produce alternating current electricity! AC ignition powered atvs have a coil on the stator that is reserved for the ignition and that never gets rectified to DC. When I said stator I meant the stator and the R/R! I have a question for you too: I read somewhere that 1 of the ground wires in your diagram connects directly to the timing pulse sensor thing(2wires, blue and green) is it better to connect the green wire on the timing pulse sensor directly to the CDI?
Old Jun 15, 2012 | 11:45 PM
Electrical Expert
Originally Posted by cesar110
Whoa! Calm down mighty LynnEdwards! Of course stators produce alternating current electricity!......
Ok, I'm all calmed down....
... AC ignition powered atvs have a coil on the stator that is reserved for the ignition and that never gets rectified to DC. When I said stator I meant the stator and the R/R!...
That's true. When you free up that extra pole formally used to power the CDI it can be used to generate more power for the 12 volt bus through the voltage regulator. But the increase in power will be much smaller than you think. Here's why:
Once you add that extra pole in the stator onto the 12 volt charging bus your AC CDI isn't powered anymore. So your new DC CDI is powered how? By hooking it onto the 12 volt bus and loading it down - taking a big chunk back out of the increase you just added.
On my GY6 150cc 8 pole stator (7 poles for the battery charging system and one for the ignition) I can get 55 watts out of the stator. It seems reasonable to assume that I can get 8/7'ths as much power to the 12 volt bus if I go with dedicating all eight poles to the task. That would give me 63 watts maximum, or an increase of eight watts.
I've never measured how much power a CDI uses. I'm going to go out on a limb using back of the envelope calculations (and subject to calculation error and correction). I calculate that at 3000 RPM the CDI will transfer 3.3 watts of power to the ignition coil. That's delivered power through the CDI and doesn't include any power dissipated by the CDI itself. Assuming overall transfer efficiency of 70% that means the total consumption would be 4.7 watts (meaning 1.4 watts go up as heat in the CDI). So that leaves you 3.3 watts ahead by switching to a DC powered CDI. 3.3 watts gives about 0.3 amps of increased reserve current capacity at 3000 RPM.
A 250cc three phase charging system may do much better. I've never measured the output capacity of one of these. It may well be the increase in output capacity is significant. I don't know.
..... I have a question for you too: I read somewhere that 1 of the ground wires in your diagram connects directly to the timing pulse sensor thing(2wires, blue and green) is it better to connect the green wire on the timing pulse sensor directly to the CDI?
If your green wire coming out of the stator is grounded inside the stator (you can measure that with an ohmmeter looking into the stator) then there isn't any point in running an additional wire from the stator to the CDI. But you still need to have a ground wire from the CDI to a good ground.
On some quads the pickup coil has two wires coming out of it. One of those gets grounded at the CDI, and the other is the signal that triggers the CDI. By grounding the return wire at the CDI (instead of at the stator) there is an increase in noise immunity (i.e. false triggers caused by transient voltages coupled from adjacent wires). Again you still need another good ground from the CDI to the engine or frame somewhere in addition to the trigger return wire. This is why the 6 pin CDI has two ground pins. Depending on your wiring scenario you either use both pins or you don't.
Old Jun 16, 2012 | 03:23 AM
cesar110's Avatar
Does it matter which pin is grounded and which pin is connected to the pick up coil(that's what you call it!)?
Old Jun 16, 2012 | 11:31 PM
Electrical Expert
Yes. Green to ground and blue to the CDI timing trigger input.
Old Jun 16, 2012 | 11:42 PM
cesar110's Avatar
No, I mean my pick up coil has 2 wires. One is green and one is blue, I want to connect the pickup coil straight to the CDI for better signal. So there are two green wires on the CDI, which one goes to the pick up coil directly?
Old Jun 17, 2012 | 01:29 AM
Electrical Expert
I bet if you take an ohmmeter and measure your actual CDI you'll find those two ground pins looking into the CDI are connected together. If that's the case (as it has been with every 6 pin CDI I've taken apart) then it doesn't matter which ground pin you use - they are the same point at the CDI internal printed circuit board.
