Starter Solenoid
Old Jul 30, 2012 | 11:17 AM
Josh Hinton's Avatar
Default Starter Solenoid
I have just purchased a 2009 Tao Tao ATA 110-D and they guy lost key so he disconnected the ignition and then the Solenoid must've went bad because it looks as if he took it off and bypassed as well. Right now it all I have to do is touch a wire to the negative battery post with the switch in run and the thing starts. My questions is how do I put the solenoid and ignition back on with wiring correctly. Does anyone have a wiring diagram? I can't find one.
Old Jul 31, 2012 | 10:44 PM
LynnEdwards's Avatar
Electrical Expert
I'll post the two common ways to wire up the starting circuitry below. Almost all 110cc quads use Plan B because it is easier to wire up the generic remote control stuff.
The solenoid is basically a remote controlled switch that can pass the 30 amps or so that the starter draws. You can't run 30 amps through a little start button! When you apply 12 volts across the two small wires on the starter solenoid current flows (about 3 amps) into a coil inside the solenoid. This generates a magnetic field, shich suck down a steel plate, and shorts the two big screw lugs on the solenoid. This connects the battery directly across the starter motor - making it turn.
Note the starter interlock in the wiring. In order to apply 12 volts across the solenoid small activating wires, all the folloing must be true:
1) Battery is charged
2) Fuse is not blown
3) Ignition is on
4) Brake is on
5) Start button is pushed
6) Ground return wiring is intact
In addition, all the wiring between the components above is intact.
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
