Kid wants dad to fix quad!
Old Sep 8, 2012 | 08:23 PM
camocap's Avatar
Default Kid wants dad to fix quad!
Bush Hog vs Bush Hog 2007 vs 2007 ATV 50 vs ATV 50
Hello all,
My little boy wants me "Dad" to fix his quad!
Please See Link
I have a 2004-2007 Bush Hog or maybe aeon Cobra 50cc quad.
My friend sold it to me for a 100.00 bucks "No Spark"
The problem is that it starts and runs great, but if it gets shut off it
will not start back up unless it sits all night.
Any help would be greatly appreciated, I will do my best to follow any
instructions you can give.
Old Sep 8, 2012 | 09:26 PM
LynnEdwards's Avatar
Electrical Expert
When it is warmed up and wont start, do you have spark? Pull out the spark plug, wire it back up, and hold the plug threads against the engine block while attempting to start. Do you see a steady spark across the plug gap at about ten times per second while cranking?
What this test is trying to determine is whether the problem lies with the ignition system or something else.
Old Sep 8, 2012 | 09:53 PM
camocap's Avatar
Sorry, I did the spark test and there is no spark!
Old Sep 9, 2012 | 07:29 PM
camocap's Avatar
4-wheeler was in garage all night.
Now it will not start at all, No spark do not see any broken wires or loose
connections.
The starter still turns over the engine!
Anyone have any ideas on where to start testing some electrical parts.
Thanks,
Old Sep 9, 2012 | 07:43 PM
Rob48060's Avatar
As crazy as this sounds try it Take the CDI and use a Hairdryer to warm it up plug it back in and try to start the ATV, I don't know why it works, no one can explain to me, I used the trick and have been riding my ATV for the last 4 days with out a problem
Old Sep 9, 2012 | 09:38 PM
Electrical Expert
connections.
Thanks,
I'm not familiar at all with your quad. I should have asked these question earlier...
1) Is you quad a four stroke?
2) Does you CDI look like any of these:
I'm reading that is was running flawlessy up to the point that you shut it off, and then it wouldn't start. Did this happen more than once? If so how many times? (These are really important questions.)
Assuming the previous question is true, (and if it isn't we need to abandon this and change course), then the major difference between a running/idling quad ignition system and a cranking quad ignition system is engine speed. An idling quad is rotating about 1800 RPM (30 revolutions per second). A quad engine being cranked by starter motor is 3 times slower at about 600 RPM (10 times per second). The unloaded output voltage from the stator on any winding is proportional to engine speed (the law of Faraday Induction), so is conceivable that a partial failure in the stator could cause a situation where it would idle fine, yet not have enough 'oomph' to start up a quad at the much lower cranking speeds. It's a stretch, but lately we only seem to be getting weird off the wall problems that don't fit in the common problem genre.
The stator heats up over several minutes, and cools very slowly. On the other hand the CDI heats quickly and cools quickly. Your symptoms still points to the stator, but please do due dilligence and find which CDI you have, and answer the other questions too as best you can.
Old Sep 10, 2012 | 01:36 PM
camocap's Avatar
How do I put photos on this thread?
Old Sep 13, 2012 | 11:49 PM
Electrical Expert
I'm really behind in my posts. My private posts are even more behind (they get lesser priority than public posts because public posts do the greater good at large).
Your cannot upload pic's until you get to a certain number of posts. I don't know what that value is, but it is probably around 20 posts. It is a barrier against spam attacks.
I put most of my pictures on www.photobucket.com (a free web picture hosting site). There are many others as well. I upload pic's there, then paste in a link in my post to photobucket. They make it easy to grab the link to your pic's and paste it into your post.
Old Aug 3, 2017 | 10:17 PM
Alan Mennear's Avatar
does anyone have a wiring diagram for a aeon cobra revo 100s 2003 with 5 wire cdi where on wire is orange ??? and could anyone help with eletric start
Old Aug 4, 2017 | 08:06 AM
LT80's Avatar
LT80 Expert
Maybe start your own thread.
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
Ashley S
May 29, 2017 10:54 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
