Wiring help
Old Nov 8, 2012 | 02:04 PM
airborne0130's Avatar
Default Wiring help
Ive read a few of the forums about this idea and I'm hopin that you could help me in this matter. I have a Sunl 50cc atv not sure the year , but my daughter broke the left handle bar switch that has the push button and the kill switch and headlight switch on it. I have attempted to just order a new one but cant seem to find one and the company is out of bussiness. It is a singe plug 6 pin. Before this broke the bike ran fine. I have attempted to cross the start and crank it that way but its not starting just turning over. I've held the brake while doing this and have had the key on. I was wondering with the kill switch not being on the bike anymore would that prevent it from starting? If so is there a way that i can cross some wires or fix this problem? Also if it helps any it has a 5 wire cdi. Aso do you have some type wiring diagram that tells me what the 6 wires are for from that switch. Thanks for the help in advance.
Old Nov 8, 2012 | 11:04 PM
LynnEdwards's Avatar
Electrical Expert
Can you put a picture of this switch in your album? You cannot upload pic's to the forum proper until you have 20 or so posts under your belt. It is a requirement to prevent spam posts to the forum.
Many quad vendors go out of business, but many of those simply assemble quads from common generic parts available all over, and which are used in many different quad brands. Rather than search for parts for specific brands, you should just be searching for "chinese six wire left handlebar switch" or something like that. If you find a pic that looks like your switch it is most likely compatible.
There is a kill switch on your left handlebar switch assembly that can prevent spark. Here is the generic procedure for testing "no spark" on 5 pin CDI's. I would look carefully at the kill switch tests, but encourage you to do all the tests just in case you've got problems in addition to the left handlebar switch issue.
Is this a picture of your CDI?
Assuming the answer is yes, the first thing to do is eliminate all kill switches and kill switch wiring:
Method 1) Unplug the CDI and remove the kill switch pin in the CDI connector on the wiring harness. The pin is held in with a spring tab on the pin itself. You'll have to probe into the connector and push this tab in order to extract the pin. Plug the CDI back in (kill switch wire dangling) and see if you have spark.
Method 2) Unplug the CDI. Turn on the ignition switch and set all kill switches to the run position. Use a meter to measure resistance in of the kill switch pin in the wiring harness connector to engine/frame ground. If the resistance is infinite on the 200K ohm scale then your kill switches/kill switch wiring are OK. If you measure zero ohms then you have a kill switch/wiring issue.
The other inputs your CDI needs to make spark are AC Ignition Power, and the Trigger signal. Do the following:
1) Unplug the CDI. In the wiring connector measure the resistance of the AC Ignition Power pin to the Ground pin. You should see 400 ohms or so. What do you measure?
2) Measure the resistance of the Timing/trigger pin to the ground pin. You should measure 150 ohms or so. What do you measure?
3) Leave the CDI unplugged. Set your meter to measure AC volts on the 100 volt scale. Measure the voltage on the AC Ignition Power pin to the ground pin while cranking the engine. You should see 40 to 80 volts AC while the engine is cranking. What do you measure?
4) Set your meter to measure AC volts on the lowest scale you have. Ideally this would be 2 volts but many meters don't go down this low. In that case use the lowest scale you have. Measure the voltage on the Timing Trigger pin to the Ground pin while cranking the engine. You should 0.2 t0 0.4 volts AC. What do you measure?
Now for measuring the output side of the CDI:
A) Leave the CDI unplugged. In the CDI wiring connector measure the resistance of the Ignition Coil pin to the ground pin. You should measure less than 1 ohm (but not zero ohms). What do you measure?
B) Plug the CDI back in. Set your meter to measure AC volts on the 20 volt scale. Set all kill switches to the run position. Crank the engine while measuring the voltage on the Igntition Coil pin to ground. Poke through the insulation of the wire if you can't probe the connector.
Caution: There should be moderately high voltage spikes on this wire. Make sure your fingers are not part of the circuitry. Don't touch the probe lead tips while doing this test.
What you should see is a lot of random numbers with lots of zero values as well. This is because the meter may catch all or part of the spark event voltage, with a lot of nothing in between. Describe what you see.
Note: Using a meter to measure this point produces highly variable results depending on the meter. What you really need is an oscilloscope, but most always a meter is all that is available. We have to do the best we can with what's available. Describe the meter results as accurately as you can - there is information there to chew on....
We can figure out the wiring to your six pin connector if that becomes necessary, but I would start out with the "no spark" tests as outlined above to zero in on *why* you have no spark.
toonces
Sep 5, 2015 01:14 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
