Carb issue
Old Jun 3, 2013 | 01:59 PM
bigge_al's Avatar
Default Carb issue
I got a Eagle scout 125cc that I have had some issues with this issue was that after cleaning the carbs the float stuck and the filter (per say) had fuel coming out until I tapped the float bowl. I had to make up a filter until my filter comes in the mail.
I have a few pics for you to look at to let me know if something is missing i.e. lines.
Adjustment screw I turned out 2 full turns
Above the choke lever something that may be a leak and you can see my temperary filter until my filter arrives(a piece of underwear)it is yellow from the gas leak
Old Jun 3, 2013 | 04:20 PM
Jaster94's Avatar
underwear? TMI, TMI!!!!!! too much information!!!!! ewww, really, yellow? bwahahaha. should've used a sock, more layers for filtration on the micron size.
above the choke is that nozzle, put a small hose on it and get that pointed away from on top of the engine. that appears to be the overflow. so you don't want gasoline to come pouring out on top of the hot engine or you'll get hot legs quickly.
Old Jun 3, 2013 | 05:28 PM
bigge_al's Avatar
Thanks I figured it needed something when i cleaned the carb I blew some air into the bowl drain and air came out of that hole.
My son road it today for the first time and there was no oil leaking. My son having never rode one alone b4 leaned away from turn instead of into it and fell off.
I need to get carb adjusted it is running rich.
My other son was unable to get on his 110cc because I could not keep it running every time I let off gas it cut off.I held it for about 3 min and still no go. I am thinking that the gas may old and that is the problem and any ideas there would be useful.
Old Jun 3, 2013 | 06:00 PM
LT80's Avatar
LT80 Expert
(a piece of underwear)it is yellow from the -->gas leak
Sure it is..
I think the red arrow is the vent.
I'm not familiar with that machine but why is the old wet filter no good?
110:: clean th carb?
Old Jun 3, 2013 | 06:04 PM
bigge_al's Avatar
No filter when I got it just a black tube the filter was lost. I checked 3 places and no one had on
Old Jun 3, 2013 | 07:07 PM
LT80's Avatar
LT80 Expert
IC
Old Jun 4, 2013 | 06:07 AM
Jaster94's Avatar
yeah, like LT80 stated, on that 110. clean the carb, pull the jets and clean them. that should fix it up.
Old Jun 4, 2013 | 10:03 AM
Pitboard's Avatar
If you are not handy just replace with the regular carb or the High Performance Mukuni at Outside Distributing . 1000's of Parts for 100's of Units. Quality parts for Chinese and Brand name Makes/Model ATV, Dirtbikes, Scooters, Small Engine and more. Chinese ATV parts.
Old Jun 4, 2013 | 01:28 PM
bigge_al's Avatar
Default Lesson learned
So I went out to the 110 cc this morning after adding seafoam to the tank yesterday and running it. Tried starting it and still no go so I adjusted the screw out some. THEN I NOTICED THE CHOKE LEVER JUST LIKE THE 125cc. I am an idiot. Jacked up the rear, cranked it with choke HA THAT WORKED DA. adjusted the screw after it warmed up to the point the back wheels did not turn at idle. so the 110 runs and no smoke.
Now to the 125cc. Adjusted the idle the same way but carb is spitting and engine revs up, throttle jumps to RPM's. I discovered that the temporary filter was allowing a lot of air in so I made a new one with 3 layer and that helped alot with the idle. I think I will need to wait until the filter arrives to make adjustments but when I do get it should I still just adjust the idle screw(what I call it 1st pic. the black arrow) I do not see any other adjustment screws.
Old Jun 4, 2013 | 06:51 PM
Jaster94's Avatar
yeah, get the filter.
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
