Kazuma Problems
Old Feb 10, 2014 | 09:55 AM
magicinmywords's Avatar
Default Kazuma Problems
I have a Kazuma Falcon 110. It was running fine, but needed the carb cleaned. I cleaned the carb really good and put it back on, and I couldn't get it to start. Ive got an adult sized Falcon 110cc, that I am having problems with, and a Kazuma Redcat 250cc water cooled that I'm having problems with too. Can anyone help me?
Old Feb 13, 2014 | 09:00 AM
tcam110's Avatar
Are you sure you put the carb/float back together properly?
Meaning is the engine getting fuel now? If you put a tiny bit [real tiny] bit of fuel right into the carb will it start?
Old Feb 13, 2014 | 07:19 PM
Yes, I am very sure. I've cleaned carbs many times before
Old Feb 13, 2014 | 08:06 PM
tcam110's Avatar
Did you try a bit of fuel right into the carb [choke]?
All you did was remove a function carb from the bike. Cleaned it and now it doesn't function?
Unless you clogged a jet while trying to clean it then I have to think something is going on with the needle/float?
Old Feb 13, 2014 | 08:47 PM
I cleaned all of the carb: the jets, the float, I cleaned where the flat sets, and the whole bowl. I know there isn't anything blocking the jets. It was all cleaned
Old Feb 13, 2014 | 08:51 PM
And I checked the petcock. The gas was flowing great. I made sure that I put the carb back together exactly as I took it apart
Old Feb 13, 2014 | 09:06 PM
tcam110's Avatar
Just seems to coincidentaly that you would remove the carb while it was running fine put it all back together perfectly and then lost spark or something on the very next time you tried to start it.
The throttle cable went back in ok?
When trying to start it does playing with the throttle do anything?
Getting spark and the plug is wet?
I personally would just pull the air filter put a tiny bit of fuel in carb through the open choke. Then close choke and see if it starts. If it does the needle isnt doing its job.
Also what did you set air fuel screw at?
Old Feb 14, 2014 | 09:00 AM
Zrock's Avatar
Super Quad Patrol
try what was stated above spray some fuel into the carb and try to start. I had the same problem and it must have been a air blockage in the carb. After a few tries of spraying fuel into the carb it would start to fire and then i had to keep it alive with the squirt bottle for a min or so and then it has ran fine on its own since
Old Feb 15, 2014 | 12:16 AM
Ok, I guess I'll try that. Thanks again
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
