Bystarter valve wiring? 90cc Manco quad
Old Jan 1, 2015 | 09:25 PM
kippstakes's Avatar
Default Bystarter valve wiring? 90cc Manco quad
Engine idles great but when gassed it bogs and tries to die. Figured it was a carb issue, but the problem persisted over all mix screw settings. While doing research I learned what a bystarter is and that I haven't wired it in, which I assume means the carb is running rich/choked.. might be the problem?.
Anyway, there are two leads coming from the valve and the wiring on this atv is a mess, it's not evident which wires need to be attached by a connector on the atv's wiring. Basically, I just want to make sure that one is 12v and the other is a ground (I can wire it if this is the case).
thanks!
Old Jan 1, 2015 | 09:29 PM
kippstakes's Avatar
Update-- I just found a diagram and it looks like the 12v/ground scenario is correct. BUT does it matter which one is which. From what I can see they both look the same, is there a way to test which is which with a multimeter?
thanks again
Old Jan 2, 2015 | 04:19 AM
Never heard of a bystarter either but an electric choke is powered from the alternator, not the battery, so the heater doesn't warm the choke until the engine is running.
Old Jan 2, 2015 | 08:18 AM
LT80's Avatar
LT80 Expert
What part are you calling a valve?
2 stroke or 4?
Old Jan 2, 2015 | 11:48 AM
kippstakes's Avatar
Thanks for the replies
Two stroke.
As I understand it, the bystarter and its valve (needle) work by heating thermowax to actuate a plunger and needle to close an additional fuel passage. As the motor runs/warms and delivers power to the heater, the wax expands and etc./refer to above. I think they only need 12v ac or dc, and my atv doesn't have a battery (kickstart only), so any 12v lead should work- since power doesn't flow while engine's off
However, I'm pretty sure I found the lead for the bystarter and plugged it in- no improvement. Guess it must be something else. The carb is brand new, so it shouldn't be dirty needles. Gas flow seems solid. Running out of ideas here.
http://www3.telus.net/MyScoot/AutoChoke01.jpg
Old Jan 2, 2015 | 02:05 PM
LT80's Avatar
LT80 Expert
I'd see if the exhaust is plugged and do a compression test.
Old Jan 2, 2015 | 04:03 PM
kippstakes's Avatar
Exhaust seems to be flowing freely, pleny of exhaust smoke coming out. Compression should be solid- just installed new piston, rings, head gasket, cyl. gasket, and spark plug.
I can check it tho. What is a good reading on this engine?
Old Jan 2, 2015 | 05:00 PM
LT80's Avatar
LT80 Expert
90 minimum. Fresh I'm thinking it should be 120.
You installed a new piston. Did you have the cylinder honed and measured?
Old Jan 2, 2015 | 05:48 PM
kippstakes's Avatar
Honed, not measured. For as much as I paid for the thing I'm not planning on sinking a huge amount of labor into this thing. I would be surprised if the bore dia is out of spec, the engine seems fairly low mileage
Old Jan 2, 2015 | 06:06 PM
LT80's Avatar
LT80 Expert
If it needed a new piston......
