Linhai 260, has spark, will not start
Old Mar 3, 2015 | 10:14 AM
MPDano's Avatar
Originally Posted by rangerjoey76
Wouldnt it at least fire with ether if it was the carb?
Yes, if it was the carb. You can even pour a very small amount of gas in the spark plug hole and it it should run for a few seconds, but "only" if you have a carb issue.
Your symptoms sounds like what just happened to me on our last Dessert outing. Ended up being low compression, which will "not" start even on ether.
Old Mar 3, 2015 | 10:20 AM
MPDano's Avatar
Well being out in the country its a 1/2 hour trip is the reason im asking.
Having proper tools will not only help you now, but also in the future. Hence, why I bring up Harbor Freight. Inexpensive tools. Some good, some not so good.
The compression readings will also give you a baseline before you start adjusting valves. Then, you can run another reading to see if adjusting the valves raises the compression. If it doesn't or only minimal, Your looking at, at least a top end tear down of your motor.
Old Mar 3, 2015 | 10:46 AM
rangerjoey76's Avatar
Well i bought the harbor freight tester. With a coupon code it came to $25 with shipping. Now I'll wait till it gets here.
Old Mar 4, 2015 | 02:30 AM
"Wouldnt it at least fire with ether if it was the carb?" Answer no, for some reason Quads seem particularly bad to start if they don't get the right fuel/air ratio. I've had quite a few that refuse to fire if the carb isn't right, despite giving them a shot of either in desperation. Clean the carb out, fit a new plug, and see what happens.
Old Mar 11, 2015 | 09:21 PM
  #15
MPDano's Avatar
Did you get your compression tester to get the reading?
Old Mar 12, 2015 | 05:03 AM
  #16
Still waiting on it get
here.
Old Mar 19, 2015 | 11:15 AM
  #17
Less than 30 pounds
Old Mar 19, 2015 | 11:40 AM
  #18
MPDano's Avatar
Less than 30 pounds
There is your answer. If you have checked the valve clearances and they are to spec and your still getting low compression. You need to rebuild that top end. Chinese quads usually sell complete kits (jug, rings, bearing and gaskets).
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
Thanos
Jul 12, 2015 08:40 PM
wannabe32
Jul 7, 2015 11:30 AM
sae156
Jun 3, 2015 01:45 PM
1000gade
May 27, 2015 12:37 PM
