No powere after putting on a new battery.
Old May 10, 2017 | 07:38 PM
bmurchis's Avatar
Default No powere after putting on a new battery.
I had a battery that I had ti charge daily. I purchased a new battery and turned the key to the ON position. No power at all. I had the new battery tested and it was fine, I have checked the fuses....All are in great shape. What should I check next?
Thank you.
Old May 11, 2017 | 02:53 AM
My guess is you put the battery on backwards and blew the main fuse. Check the terminals are clean and tight. Double check those fuses, there may be a separate, in line, main fuse that isn't in the fuse box. On most Suzukis and Yams it is built into the starter solenoid.
cornermike
Aug 13, 2016 09:33 PM
CT22Canada
1) Engine problems..
Aug 10, 2016 12:03 PM
zanerojo
Aug 10, 2016 11:29 AM
nytlaw
Jun 17, 2015 01:16 AM
thirtynineoff
Feb 5, 2009 10:08 AM
