Help...Tao Tao kids ATV. So I bought my kid a Tao tao
Old Jun 16, 2021 | 11:00 AM
realtreecamo's Avatar
Default Won't start
Originally Posted by Kymco 450i
Many have reported even new parts on these cheap Chinese machines can be bad.
One day my kid 4 wheeler wouldn't start it's a 2020 110cc jasscol ran fine then it would start at all I have bought new starter, battery, starter solenoid, and still nothing will would start with jumper cables a few times now nothing we have only had it for about a month
Old Jun 17, 2021 | 02:22 AM
Starter, battery and solenoid are all parts that make the engine spin over for starting, so is your problem that it won't spin on the starter?
Old Jun 20, 2021 | 11:36 PM
It won't do nothing at all no clicking no rolling over absolutely nothing
Old Jun 21, 2021 | 02:18 AM
Just answered a similar post:-
I can only supply generic solutions, there should be two thin wires to solenoid relay, and two thick ones. One thin comes from the start button, the other from either pos or neg on battery, but can be wired through other things too, as can the wire from the start button. The pos wire goes from battery, through a fuse then ignition switch, then it may go to a brake light switch before going to either solenoid relay or start button. Neg side may be direct to either start button or relay, or again, it could go to a brake light switch first. Some use a neutral light switch instead of brake switch, bigger bikes often use both, and add complex diode and relay systems as well. To be sure it isn't the solenoid relay, disconnect the thin wires and put a 12v incandescent test light across these wires that come from the loom to it. Switch on, brake on, in neutral, press start button, if lamp lights brightly, faulty solenoid relay. If it doesn't, check which wire is dead.
crankestein
1) Engine problems..
11
Jan 30, 2021 06:32 PM
Kanderson7271@gmail.com
Apr 26, 2016 08:58 AM
Faticxmaticx
Dec 20, 2015 10:18 AM
hawaiianbasshead
Jun 16, 2010 02:35 PM
Cmott426
Jun 23, 2007 06:15 AM
