Chinese 110cc ATV (Coolster3050c) wont start
Old Dec 29, 2018 | 10:36 PM
Jass3050c's Avatar
Default Chinese 110cc ATV (Coolster3050c) wont start
Hey guys,
I am new to the world of Chinese atv's and decided to give it a try due to reading a lot of reviews that they sometimes last at least a few years. Purchase a brand new Coolster 110cc model 3050c to be exact and my some rode it twice and I opened the throttle some and it ran fine that day and now it just turns over but will not start. I have confirmed it is getting fuel and has spark also as I stated before it is brand new with a fully charged battery. Was told by the shop I bought it from when I returned it for them to check it that is has no compression. Can anyone please help me to figure out how to restore compression and would I just need another motor. Any and all help would be greatly appreciated. He is looking forward to going ride again over the weekend and I am kinda upset I won't be able to make it happen without any help. Thanks in advance
Old Dec 30, 2018 | 03:50 AM
If you are very lucky, you may just need to re set the valve clearances. If you are not lucky, you may have seized the piston, or a valve could have come loose. If re setting valve clearance doesn't fix it, a strip of the head and cylinder is needed to find out what went wrong. Trouble is, on an engine this new, a seizure could be down to a faulty oil pump or un-drilled oilway, so you have to be sure of why it seized as well, if that turns out to be the problem.
Old Dec 30, 2018 | 10:13 AM
Jass3050c's Avatar
Will try to reset the valves when I get off and post the results. Hope I do get really lucky
ian86
1) Engine problems..
Jun 5, 2020 10:27 PM
Hollywoodbadguy
Jun 2, 2016 05:25 PM
Hollywoodbadguy
Technical and How-To Articles
May 2, 2016 02:46 PM
ian86
May 31, 2014 05:07 PM
rsekrecre1
Aug 29, 2008 11:01 AM
