2) Chassis problems.. If your quad runs but you have other problems.. post in here.
RAPTOR 125 Loose Throttle
Old Jul 18, 2021 | 07:53 PM
06dtx's Avatar
Question RAPTOR 125 Loose Throttle
So after cleaning my carb on my Tao Tao Raptor 125 my throttle got loose... I dont really know how to explain it but I have to push a the throttle in a little bit more than half of the max it goes before it even starts accelerating... I think it has something to do with the cord that goes down to the needle in the carb but I dont know how to fix it...
Old Jul 19, 2021 | 02:19 AM
Cables are adjustable, usually by lengthening the outer where it screws into the box on the handlebars. However as this suddenly occurred after a carb cleaning, most likely you have lost a ferrule off the end of the outer cable, where it goes into the carb.
Old Jul 19, 2021 | 08:36 AM
06dtx's Avatar
What would be the fix if that is the situation? It might be that because I had cleaned the carb 2 or 3 times since my ATV wasn't reaching the top speed like before and even after cleaning it it still doesn't
Old Jul 20, 2021 | 02:11 AM
If it is missing, try to get hold of the ferrule. Almost certain to be a copy of a Honda engine and carb so Honda C90 Cub parts should fit. If there is nothing missing, adjust the cable adjuster to give 1/4" movement before it starts opening the throttle.
Michael Sullivan
Sep 24, 2020 09:29 AM
Dc22ball
3) General Discussions..
Dec 2, 2019 04:33 PM
Bamajoker
Nov 15, 2016 10:22 PM
Chelle17
1) Engine problems..
Apr 12, 2012 09:52 AM
konefour
Mar 18, 2010 12:40 PM
