Apollo blazer 9 headlight issue
I bought 2 brand new outta the crate apollo blazer 9s for the kids for christmas, both of them the headlights come on when the key is turned on. Even with the headlight switch off. I dont think thats normal being that there is a headlight switch. So the switch does absolutely nothing for the lights
Are you sure the switch isn't hi/lo beam? If it isn't, it would seem that the factory has got the wiring wrong, and it then depends on whether you are bothered enough to do something about it. You could leave things as they are, though it will take longer to charge the battery. If the kids are not going to ride at night anyway, an easy fix is to remove the bulbs. If you are good enough at electrics, you could find the fault and mend it.
