400 EX popping !!!!!! any ideas ??????????
Old Jul 21, 2003 | 08:29 PM
FsT4WrD's Avatar
Default 400 EX popping !!!!!! any ideas ??????????
One of the EX's I ride with has WB exhaust , CDI and was jetted and Dynoed by a local shop . It was taken there because it would pop every time you shifted , after it was rejetted it ran great for the first day then second day it started doing it all over again . So took it to another place to have the carb checked out to see if it needed a rebuild , the guy kept it for a day or so cleaned the carb and rode it and said the popping is gone and it is now fine .
Well no after riding it for about 5 hours its starting to pop again.
Any ideas ?????? other then upgrading with a new carb..... we would like to keep this carb do to other mods have been ordered (suspension/axel)
Old Jul 21, 2003 | 08:58 PM
HA2's Avatar
HA2
popping i assume you mean backfiring????
Old Jul 21, 2003 | 09:52 PM
FsT4WrD's Avatar
Yep , it don't backfire and spit and sputter , it just gives one backfire and a miss then it goes till you shift again
Old Jul 22, 2003 | 05:03 PM
HA2's Avatar
HA2
you try your manual? a lot of times they have a troubleshooting section that is useful. when you shift you're coming down on the RPM's, does it do the same in neutral when u snap the throttle real high and let it come back down to idle on its own?
Old Jul 22, 2003 | 08:28 PM
FsT4WrD's Avatar
Np manuel , and yes it will do the same if you snap it in idle and let it come back down .
Old Jul 22, 2003 | 09:29 PM
dariusld's Avatar
Have you checked for an exhaust leak?
Old Jul 22, 2003 | 09:45 PM
WISTECH's Avatar
Did you put new exhaust seals in when you changed your pipe. If there is a leak it will draw in fresh air into your exhaust when you let up and ignite the unburned gases in the exhaust. POW
Old Jul 22, 2003 | 09:47 PM
HA2's Avatar
HA2
my 200 did the same. someone said an inproperly gapped plug will do it too. [img]i/expressions/face-icon-small-confused.gif[/img]
Bratman2
Aug 6, 2022 01:42 AM
Shainasmash
May 8, 2017 06:38 PM
switzomatic
Aug 24, 2015 12:57 PM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
ghost civic
Jul 19, 2015 10:13 AM
