650p belt help
Old Aug 24, 2003 | 09:59 AM
crazy22's Avatar
Default 650p belt help
went out riding the belt light was flashing lost 4wheel drive and can not go over 8miles and hour
any idears
Old Aug 24, 2003 | 10:29 AM
therock's Avatar
Pully's stuck open? Belt separation? Sensor failure? Can't wait to hear what it is!
Old Aug 24, 2003 | 11:20 AM
Albee39's Avatar
Check out NyRoc's web site http://atv.dnsalias.com/ he has good info. One thread on how to reset the belt sensor. Good Luck.
Old Aug 24, 2003 | 08:44 PM
KISSSOFDEATH's Avatar
Your "Drive belt failure detection switch" may be tripped. For a quick check I would suggest removing the cover and checking the switch. Nothing is going to jump out when you remove the cover. Just remember dont turn the key on when its removed. You will see the switch at the top of the cover. The hand should be toward the ON position. If it is not then you need to put it there and adjust your belt or have your dealer do it for you.
Good luck
Tim
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
