BeLtS HeLp
Old Sep 9, 2003 | 06:51 PM
savage21's Avatar
Default ((((((((((()))))))))))BeLtS HeLp
ok this is my first belt change i burnt it out pulling a actic cat 454 out, well how hard is it to replace and should i be able to do it .I havn't took the cover off to take a look i'm scared to i notice a lil burn place on the cover no hole just a place where the plastic heated and bubbled up. i also have another question what should be my first hop-up for my scrambler 400. I was thinkin a pipe a rcr which should middle. or low end pipe, all i ride is with friend in the woods. and in BAD mud
Old Sep 9, 2003 | 07:04 PM
CED's Avatar
CED
Very easy just spin your secondary by hand and guide the belt off by hand.Rick Ritter stage one is hard to beat for the money.
Old Sep 9, 2003 | 07:17 PM
pacothemonkey's Avatar
yeah belts are very easy to change and its not as scary in there as you would think, very simple. Yeah i would recomend geting a kit instead of just a pipe, that way all the parts, clutch and exhaust, will work the best possible. If you do get a kit changing the clutch spring and all that is kinda technical and dangerous i'd take it to a dealer or shop who knows about polaris'. i'm getting the RCR stage 1 kit my self next week. Should be fun!
Old Sep 10, 2003 | 01:13 PM
Russ7R's Avatar
The clutch kit is not dangerous to change....you just need a good set of snap ring pliers and an extra set of hands to get the helix in an out, following the directions to a T and you will be ok.
I wish they would include some pictures of the primary and seconday clutchs so you could have saved any doubt at first on what you are doing and what each part is, I know it it preatty much self explain but pictures are worth a thousand words.
Russ
Old Sep 10, 2003 | 01:42 PM
oh i just read online that it was dangerous cause the spring was under presure and could shoot out or some junk... i guess if you had two people it wouldnt be so bad
Old Sep 10, 2003 | 06:52 PM
lovemud's Avatar
Default BeLtS HeLp
Make sure the belt goes on so the writing is readable ( right side up ) as you put the belt on. once they get broken in they only work in one direction.
Old Sep 12, 2003 | 11:51 AM
kyxplorer's Avatar
Default BeLtS HeLp
i only weigh about 160 and i have changed out my springs several times by myself- don't worry about it- it just takes time. as for a belt i would go to a kevlar belt and you can get the same one HPD sells at NAPA for $29 part number 19AT4090-will save you some money. i use this belt for trail riding and racing. If you trail ride mainly check out the Hillclicker clutch system - personnal i prefer it over the hpd system and RCR- just my experience. If you are getting the pipe i would recommed a UNI dual stage air filter and main jet. good luck
Old Sep 12, 2003 | 02:45 PM
Russ7R's Avatar
Default BeLtS HeLp
Sorry I edited my post....
Russ
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
