Black secondary spring?
Old Oct 1, 2003 | 11:45 PM
rutwad's Avatar
Default Black secondary spring?
Will running the black secondary spring decrease top speed?
Old Oct 1, 2003 | 11:51 PM
trailride's Avatar
02 650no it wont. just larger tires will slow ya down a bitnapa #7335epi black secondaryK&N filterwarn 2500NYROC exhaust mod
Old Oct 2, 2003 | 12:09 AM
MUDDIN650's Avatar
NO IT DIDN'T SLOW ME DOWN AT ALL..
Old Oct 2, 2003 | 12:34 AM
MikeyBoyesq's Avatar
Rutwad,
I recently did some timed tests with the black secondary spring. You can read about it in my thread entitled "EPI Black Spring Drag Test on Asphalt" on this forum. The results on my quad (with 25 inch tires) were that the black spring does NOT reduce top-speed or acceleration times at 100 and 300 feet. In fact, my tests showed practically identical top-speeds and acceleration times with and without the black secondary spring.
happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 2, 2003 | 12:49 AM
rutwad's Avatar
Thanks for the quick replies. I will be ordering the black spring soon!!
Old Oct 2, 2003 | 08:24 AM
trx450's Avatar
Thanks guys, I always thought that the spring dropped top speed. I am GLAD I was wrong! It just "felt' a little slower. I never timed the top speed.
Old Oct 2, 2003 | 10:28 AM
WheelCow's Avatar
Originally posted by: MikeyBoyesq
Rutwad,
I'm curious (and maybe a bit confused), if your conclusions are that top-speeds and acceleration were nearly identical with and without the spring, what then is the advantage of the black spring? Belt life?
Old Oct 2, 2003 | 11:51 AM
trx450's Avatar
BINGO-- more belt life! My '02 P-650 had almost 3K miles on the original belt, and had one more adjustment to go, before it was out of spec.
Old Oct 2, 2003 | 12:01 PM
Wheelcow,
TRX is 100% correct. The additional pressure of the black secondary spring should result in less belt slippage and therefore give the belt and clutch pulleys longer life. Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
Sassinm1
Sep 30, 2015 04:23 AM
