Clutch
Old Nov 1, 2003 | 07:54 PM
Scramblerman03's Avatar
Default Clutch
Buying a new clutch from HPD soon and I don't know if I have to get the clutch puller or does it just make the job easy?
Old Nov 1, 2003 | 08:46 PM
pest44's Avatar
Default Clutch
Got to have it (or adaptation of one) to pull the primary clutch, but you should not need one for the secondary clutch.
Old Nov 1, 2003 | 10:04 PM
Default Clutch
Where is the best place to look for a puller? Would a local dealer sell them?
Old Nov 1, 2003 | 10:53 PM
pest44's Avatar
Default Clutch
Some people from other forums say that they have gotten them from dealers, but my local dealer won't sell them. I got mine from EPI. I think they are a little pricy for what you get, but they work like a charm. According to the ones who got them from dealers at cost, they were about half what I paid for mine. I think all polaris primary pullers are the same so you may be able to find one used or on ebay. Some people say they just use a bolt with the same threads, but I just went for the puller.
Old Nov 1, 2003 | 10:54 PM
scrambo's Avatar
Default Clutch
Are you installing an agressive clutch kit from HPD or replacing the primary clutch itself? I just installed the kit on my Scrambler today. I did not have to remove the primary clutch to do this, I did remove the secondary clutch to install a new helix and spring. No puller was needed for doing this.
Old Nov 2, 2003 | 08:52 AM
JakTrailboss's Avatar
Default Clutch
Junt went thru the clutch process on my Polaris, get a 4 or 5 inch bolt from your local hardware or Nut&Bolt dealer. It is 3/4" fine thread. Use a spacer in front of the bolt - about 4 inches or so. Tap the bolt a little as your are tightening.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
