light switch ?
Old Dec 25, 2003 | 05:45 PM
ftwflh's Avatar
Default light switch ?
Do you have to get the whole handlebar assymbly just to get the light switch.Does anyone have a old one that they took off because the overide or starter switch went bad but the light switch is good?
Old Dec 26, 2003 | 08:33 AM
quadwrench's Avatar
Only way they come is as the "Unit". I'm assuming you've already tried to take the switch apart and clean/repair it?
Which "Unit" do you have - (there are 3 different part #'s for the older bikes) - which bike does it fit??
Old Dec 26, 2003 | 10:15 PM
ftwflh's Avatar
I have to take the handgrips off to get to the screws that hold the housing on and I dont think I am goig to go to that much trouble.When I get my manual on this bike I will splice into the right wires and put on another switch for the head light.(the switch acts like the spring and plastic holder are broken)
Old Dec 27, 2003 | 09:42 PM
ftwflh's Avatar
Took it apart and the spring that holds the ball inplace was gone.I need a light switch spring.You know anyone who has a old assymbly that was changed because the starter switch or override was bad?
Old Dec 27, 2003 | 09:49 PM
scrambler420's Avatar
im not sure what the spring looks like,but maybe try bringing it to youe local hardwear store and matching it up with something..
Old Dec 27, 2003 | 09:53 PM
ftwflh's Avatar
going to try that monday.I hope I can fix this thing a new assymbly is $100.
Old Dec 28, 2003 | 10:44 AM
quadwrench's Avatar
Sometimes the spring out of a cheap "clicker" ball point pen is the right size (don't remember how many of the radiator fans with failed brush springs or starter buttons I've fixed this way), another option for different sized springs is one of the kid's broken remote controlled cars.
Old Dec 28, 2003 | 11:39 AM
modquad's Avatar
A good soaking with CRC 2-26 electrical contact cleaner sometimes helps. Let it sit for a bit, then "exercise" all the switches. Leaves behind a nice protectivie oil film also.
Old Dec 28, 2003 | 04:51 PM
ftwflh's Avatar
A 45 cent spring and a couple hrs fixed it.Saved a $100.All it takes is time and you can figure out almost anything.
skinnyr6
Aug 25, 2023 02:18 AM
ScopeZ_
Jul 28, 2015 01:44 AM
jayking232003
Jul 23, 2015 05:48 PM
Derek Allen
Jul 22, 2015 09:25 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
