how many clutch plates!!!???HELP!!!????!???!??
Old May 13, 2004 | 11:58 PM
BigPink's Avatar
Default how many clutch plates!!!???HELP!!!????!???!??
I am completely confused! I have an 03 DS and I smoked the clutch. Well I tore into it and counted 7 frictions and 8 steels. Now when I went and bought my new stock plates and frictions I had 8 of each! Hmmmmm. I got a schematic of the clutch set up from the dealer and it shows 8 of each. So did Bombardier forget one or what?! Plus I am questioning the "odd" plate. That is the outside plate right - the last one to go on? And it is offset from the others right? So it would line up with the shorter grooves and not the deep ones the other plates go in.
Old May 14, 2004 | 12:13 AM
400CatDriver's Avatar
I just replaced mine for the 2nd time on the '04. Yes, there should be 8 of each in the basket. One of the friction plates flanges are milled slightly smaller than the other 7. That's the one that goes in the outside offset in the slots. Maybe you got screwed by Bombardier too. My bike had one of the oil check valves fall out after the first time I rode it. Their quality control is not too impressive.
Old May 14, 2004 | 12:14 AM
sandcrazy10's Avatar
Eight of each is right and the last plate goes in the shallow groves your right
mike
Old May 14, 2004 | 01:43 AM
BigPink's Avatar
Awesome guys. Thanks for your help.
Old May 14, 2004 | 09:33 AM
SANDMAN430's Avatar
did you replace the springs while you were in there?
Old May 14, 2004 | 10:01 AM
BigPink's Avatar
Yeah I am replacing the stocksprings with Ron Woods 60% springs
Old May 14, 2004 | 10:21 AM
bombdsbaja's Avatar
Hey guy's,
This is a little off subject, but approx. how much is a replacement clutch from bombardier?? I'm doing fine now but just thought it would be a handy little bit of info for me to have.
Thanks,
Tom
Old May 14, 2004 | 10:38 AM
I think I paid about 130 for mine. Don't forget the gasket although I didn't have to replace mine. Bad luck says you'll tear it if you're not careful. I put Pami springs in mine and it made the clutch hit harder. Its a lot harder to pull now but they're stronger than the Ron Woods springs too. Don't buy them if you have carpal tunnel syndrome!
Be sure to check the clutch activator. Thats the little shaft that comes out of the middle of the basket. I lost a tooth on mine and had to replace it too. It was another 30 dollars.
Old May 14, 2004 | 10:53 AM
BigPink's Avatar
I paid 150 for my stock plates and frictions just two days ago. I think I will be happy with the RW springs. I thought the stock springs were way too soft anyways. But what do you expect with a friction plate missing! lol
Old May 14, 2004 | 11:10 AM
Yeah, I think I'll end up with a left forearm that looks like Popeyes after pulling on that clutch lever. That thing is tough. We just made a trip to Little Sahara and I burnt the clutch up in the first 3 hours. That sucked. But, now I have a spare clutch and know how to change them!
lonerider856
Oct 13, 2023 03:45 PM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
