Aeen Clutch kit 700 EFI
Old Sep 3, 2004 | 10:05 PM
67bullet's Avatar
Default Aeen Clutch kit 700 EFI
Not real impressed with the Aeen kit I just installed. Can't get it to shift while the motor in running. Bike wants to creep at an idle, you have to hold the brake. To go from low to high or reverse you have to kill the motor. I pulled it apart and put the factory primary spring back in and left the 53 ounce weights and still the same thing happens.
I didn't install the shims in the secondary, anyone know what they do?
Old Sep 4, 2004 | 12:35 AM
rapidfiremeyer's Avatar
Sounds like a problem my machine had.....I didn't have a clutch kit but both my primary and secondary needed shimming.......install the shims and see what happens helped mine a bunch
later
Rapidfireman
Old Sep 4, 2004 | 02:46 AM
Polaris500HO4x4's Avatar
thats what i thought was wrong with mine. i took it all apart my bearings were locked up [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Sep 4, 2004 | 02:24 PM
67bullet's Avatar
Not sure how to take secondary cluth apart to install shims. Pulled spring and weights back out and put stock ones back in, for now.
Old Sep 6, 2004 | 10:32 PM
rich700's Avatar
Call aaen they will explain. Rich
Old Sep 13, 2004 | 06:42 AM
BOOBEAR's Avatar
i had same problem on 02 500 h.o..........turned belt around took care of problem. good luck
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
