300ex problems
Old Nov 29, 2004 | 07:20 PM
flwkwitt's Avatar
Default 300ex problems
I took my 300ex to our local riding area over the weekend and as usual, it ran great. UNTIL, all of the sudden, it died. It restarted no problem but ran terribly. It only takes a little throttle before it dies. It runs okay with the choke on but with the choke off it sounds like its getting too much air. Air filter is good, gas is new and good, plug is new and good. Can someone tell me what to look at to find my problem. This is a 2000 model and the only problem I've had since new.
Old Dec 1, 2004 | 04:52 PM
hondabuster's Avatar
Its possible the riding around stirred up the setiment in the carb float bowl, and then got sucked up into the jets. Does it run better now? Drop the float bowl and look for crud in the bottom of it, and if you find stuff in there, the carb needs to be cleaned out. At the minimum, pull out the pilot jet and try looking thru it, like looking thru a straw. the hole is very small, and if you cant see light coming thru it, it will need cleaning out.
And if you find crud in there, put on an inline fuel filter, while youre doing the carb cleaning.
Old Dec 1, 2004 | 05:58 PM
flwkwitt's Avatar
Hey thanks much. I just got my honda 300 4x4 rolling again. I'll be pulling the ex into the garage next.
Old Jan 15, 2005 | 01:43 PM
flwkwitt's Avatar
Help, I took my carb off. Completely cleaned it, including the jets, and reinstalled it. I took it for a spin before I loaded it to go to our local riding area. It ran great, until it happend all over again. I rode it for about 15 minutes and everything was fine. I turned and headed back to the house to load it and the symptoms came back again. Idles, but cuts out and backfires really bad when you try to give it more than just a little throttle. My question do you think this is a symptom of after it gets hot or did I maybe just suck up another piece of debris into the jets. I haven't put an inline filter on it yet. That is still in my plans.
Thanks,
Forrest
Old Jan 15, 2005 | 09:22 PM
Gimpster's Avatar
It is possible that some could have sucked back into the jets, but it sounds like a coil is going bad.
----- Gimpster -----
Old Jan 16, 2005 | 10:51 AM
weewane's Avatar
look in the bottom of your gas tank to see if u see any rust mine did that from time to time I cleaned tank and treated it with a antique car gas tank treatment cleaned the carb and runs like a top now might want to try that
Ps. i so wish my tank was plastic.
Old Jan 16, 2005 | 02:10 PM
TractorPacker's Avatar
Do you have a balloon?
Sounds like the timing may have skippied a tooth. They idle great but pop and sputter when they are off time. You have to pull the rockerbox to check it, but that might be the problem. Timing chains wear out and that might be it. Not a huge thing but not fun either.
Old Jan 16, 2005 | 02:23 PM
DarkManX's Avatar
had that problem with the recon drain the carb and adjust the float bowl and if needed fool around with the jets it will run like new well mine did
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
