650 Belt Adjustment
Old Mar 27, 2005 | 08:58 PM
MuddyPup's Avatar
Default 650 Belt Adjustment
My '05 650 needs a belt adjustment after 150 miles. I have about 1.5 inch in deflection. Noticed it required a special tool for holding down the wheel to loosen the center nut. Any tips for getting the nut off w/o that tool? ...I do not have a impact wrench.
Old Mar 27, 2005 | 11:44 PM
RatherBeMuddin's Avatar
Try this link, it gives a couple pointers http://atv.dnsalias.com/techtip.cgi?...irie&viewtip=1
Old Mar 28, 2005 | 09:00 PM
limrok's Avatar
..Muddy.....u can use a bar to hold the primary...........and turn the nut off.........remeber it is left hand thread......to pull the primary u need a clutch pulling tool and it will tread in right hand ......you have to takea shim or 2 out of the secondary to t9ght9n the belt...the deflection should be no tighter tham 17 mm
.....wish u luck
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
