gallop 150 problem
Old Jun 20, 2005 | 09:42 PM
NBake's Avatar
Default gallop 150 problem
i have a national motors gallop 150 and i it has problems running 1/2 to full throttle. ive cleaned the carb, adjusted the floats, checked the plug, and checked the air filter. the next thing i want to do is adjust the valves cause its been awhile since thats been done, but dont know the valves specs. any1 have an idea what they are? what other things could be causing this problem? this has been a big PITA so all help is appreciated. Thanx!
Old Jun 21, 2005 | 08:28 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
If it is similar to a yamoto 150 you could use .002 cold. That is what I set my honda thumpers to and also the yamoto. If you are still using the stock chinese plug it could also be the problem.
Old Jun 24, 2005 | 07:52 PM
KTM Patrol
Former Chinese POW!
Any luck fixing it yet?
Old Jun 25, 2005 | 11:24 AM
NBake's Avatar
i just had shoulder surgery bout 3 weeks ago so i cant really work on anything right now, and my dad has been busy at work so we havent been able to work on it that much. but hopefully within a week or so i think i should be mobile enough to try and work on it. thanx for the specs tho, this thing has been runnig crappy the past year and i gave up workin on it in the winter. i just want to get it running good so it doesnt sit around so much!
Old Jul 12, 2005 | 12:12 AM
NBake's Avatar
i put it all back together tonight and it wont run. i adjusted the valves to .002mm int. and exh. any1 have an idea what the valve specs are for a lt185,lt160, or somethin within the 150cc range?
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
