scrambler 500 clutches which one???
Old Jul 11, 2005 | 02:34 AM
beltburner's Avatar
Default scrambler 500 clutches which one???
i have a 2004 scrammy 500 its totally stock.. i keep burning the belts when im out riding hard and getting stuck in thick mud.which clutch kit is the best?--dalton industries DSC500--HPD kit or the Team roller secondary unit. i want some serious bottom end as im 6'0 and 290lbs.all i ride is hills and mud. please help
Old Jul 11, 2005 | 11:11 AM
lslubecki's Avatar
Thick mud is the problem with the belt. Sounds like you might need a low range trans from and Explorer 400.
Steve Lubecki
Old Jul 11, 2005 | 06:12 PM
ftwflh's Avatar
For better bottom end try putting a White Bros Muffler on it will help.On your belt smoking you cant take a Scrambler into the deep stuff that the Sportsmans go through because you dont have a low gear.On the clutching if you have the cash go for the TEAM roller from HPD tell them what you want and they can set you up with the right set up on it but I dont like their primary clutch it engages too high for my liking.I like lots of low end for tight trails.Check my sig for how my 500 is setup for an idea of what works.I weigh in at 230 so it may be a good setup for you.
Old Jul 11, 2005 | 06:16 PM
Kevin108's Avatar
I'm 230 lbs too and do mostly hills and jumps. Low end is where it's at for me. Is your yellow primary a stock spring? Give me a general rundown on what swapping in these springs is like. I read the instructions on heelclicker.com but it just tells you about the parts installation, not about what you have to remove from the bike or anything about where these springs even go.
Old Jul 11, 2005 | 06:28 PM
ftwflh's Avatar
The Polaris yellow primary spring raises the engagment a little over the stock(blue/green) with a lot higher shiftrate giving more rpm on the topend.You have to be careful and use a tach to get your rpm right or you can get the shiftout rpms up past the safe zone of your motor.It took me many hrs of changing springs and weights to get mine where I want it. If you are really interested in the CVT system Aaen makes a tuning manual that explains how it all works and is very helpful.
Old Jul 11, 2005 | 08:53 PM
Kevin108's Avatar
WOW this sounds so complicated I'm now discouraged. Stock is safe.
Old Jul 11, 2005 | 10:03 PM
garrett5462's Avatar
lol
Old Jul 11, 2005 | 10:21 PM
ftwflh's Avatar
If you want better performance with a stock 500 Scrambler go with a white or green polaris primary spring(white engages lower than the green but the green will get you a bit more rpms) set the secondary spring at 2-2 and you will be ok and you will think you have a new machine you may loose a little the the top but it will be worth the $20 you spend on a spring.
Old Jul 12, 2005 | 02:38 AM
XpLo400's Avatar
Hey i recently installed a white primary on my scrambler 500 2005 and i was wondering whats the deal with the secondary?I always hear peoples saying set the secondary at 2-2...How do you do that?2-2 is the stock position of the secondary?
Old Jul 12, 2005 | 06:07 PM
ftwflh's Avatar
Stock secondary setting is 1-1 on the newer Scramblers 2-2 will get you bettere backshift but cut you a little on topend.You have to take the clutch apart to check and change the settings.
fordfaithful21
Dec 7, 2015 05:52 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
1000gade
Sep 9, 2015 03:35 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
