My Warn winch has issues...
Old Aug 15, 2005 | 10:02 PM
05PRED500's Avatar
Default My Warn winch has issues...
or, maybe it's me. Out of the 5 times using my winch, 3 times my winch cable jammed. Inevitably, the stupid thing gets wound up on one side then jams. This time, it is really bad. each time, I try very hard to try to evenly winch in too.
This is frustrating and I have to do something. Has anyone used the rope type of cable? Does it do any better?
Old Aug 16, 2005 | 12:27 AM
nfox's Avatar
I just installed my warn about a week ago and i just noticed that my switch is backwards, when i press out it pulls the cable in and when i go to press in it feeds out cable, what is my problem?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 16, 2005 | 12:31 AM
carpenter's Avatar
UNWIND THE CABLE ALL THE WAY OUT THEN IT WILL BE RIGHT.
Old Aug 16, 2005 | 12:50 AM
05PRED500's Avatar
Normally, yes. This thing is sooo caught up, I can't get it to freespool or wind out.
Old Aug 16, 2005 | 01:37 AM
Bretman's Avatar
The reason the thing goes out when you press in is because you have the wires crossed somwhere. I have had the same prob with mine. It is a simple fix. As for the guy who has the winch issue, if you camt get it to unravel, hook it up to somthing, put the quad in reverse, and push the out button on the winch to let cable out and hopefully when you give the quad gas it will start to come out.
Old Aug 16, 2005 | 08:47 AM
scootergptx's Avatar
Supersock
Hired Gun!
When you first installed it, did you stretch the cable? Hook up to something and let out all the cable (when you can) and back up (assuming it's on the front). Found that on either Warn or Ramsey's site in guide to winching. Wouldn't have thought of it, but it does make sense. If you've only let out say 20 feet, it may have stretched (not talking inches, just enough to matter) and could cause problems when you roll it back up.
Old Aug 16, 2005 | 11:35 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
nfox
Let your cable all the way out and press the in button. If your cable was comming off the top of the spool, it will change to the bottom. If it was comming off the bottom it will change to the top.
When winching watch the cable and make sure it dosen't spool on one side, if it dose stop winching let some cable out and spool it in even then winch again.
After useing my winch when I get home I unspool the cable hook it to my wifes quad with the parking brake on. Winch her quad in and spool my cable on evenly with some pressure. This keeps the cable tight and will dry any moisture that may have gotten in the winch motor.
Old Aug 16, 2005 | 06:02 PM
nfox's Avatar
Thanks for the info Guys!!![img]i/expressions/face-icon-small-happy.gif[/img]
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
