Clutch basket removal.
Old Nov 2, 2005 | 07:06 PM
Troyer23J's Avatar
Default Clutch basket removal.
How do i get the nut off the clutch basket? It wants to spin the clutch.
Old Nov 2, 2005 | 08:47 PM
Troyer23J's Avatar
I tried an impact wrench, but no luck. The "Boss Clutch" spins inside the basket.
Old Nov 2, 2005 | 09:35 PM
raptorider660's Avatar
try putting something really strong on it and it will hold it and will not move thats what i did
Old Nov 2, 2005 | 09:52 PM
Bradracer18's Avatar
usually......or atleast it is this way on the predator......you can hold the clutch by a nut that is on the opposite side of the quad.....on the flywheel(there is a little plug that you take out....to access the nut)......
now I dont know if the quad you are working on is like this or not.....might be worth checking though....
Old Nov 3, 2005 | 01:44 AM
MDS2106's Avatar
You can pop rivet a steel and a clutch fiber plate together,slide them in and then use the impact.Or easier than that,you can take a small to med. towel ,start on one end and twist it then take a screwdriver and push as much of the towel in the basket as you can then use the impact.The towel will sure work in a pinch......By the way they do sell a tool for that
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
