2000 foreman 450 es
Old May 3, 2006 | 03:17 PM
arctichondacat's Avatar
Default 2000 foreman 450 es
My rear brake is seized in that if I apply it, it sticks on, otherwise the wheel rotates fine if I don't use it. I went to take it apart for repair but I could not get the hub off. I loosened the cable completely,, but still no luck. Should I put my three arm puller on it? I was worried about tearing the whole assembly off. Any thoughts?
Old May 8, 2006 | 10:29 AM
33 views and no replies? Does anyone have any thoughts on this?
Old May 8, 2006 | 12:38 PM
quicksilver's Avatar
well i havent had one of those apart, but i would be careful using a puller on it because you could warp the hub and the wheel will wobble. I would buy a manual and make sure you are taking it apart correctly first.
Old May 8, 2006 | 02:16 PM
Thanks quicksilver, the manual says to 'slide it off'. I figured if I had this problem perhaps someone else will have and have a tip. I will just have to go really slowly with the puller I guess.
Old May 8, 2006 | 09:16 PM
mykool61679's Avatar
???????????????just put it in reverse brake the bolt loose and tak hub off.it shouldnt be that hard.
Old May 9, 2006 | 09:25 AM
you would think, I used my impact gun to take the nut off, it is the hub that won't slide over the brake shoes. It's pissing me off! I will have to use my puller and try to ease it off without tearing the brakes off.
d
Old May 9, 2006 | 11:55 AM
sandpit's Avatar
DO NOT USE A PULLER!!!
Mine is a 99.There is a lock ring that is made from small round stock.It goes around just on the inside edge of the drum.
Old May 9, 2006 | 11:58 AM
wow thanks I will check it out.
d
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Gwolf228
Feb 18, 2017 01:36 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
mark23
Oct 1, 2015 09:57 AM
