Resolved:Sportsman 500 Reverse and speedometer problem
Old May 26, 2006 | 08:15 AM
dmach8's Avatar
Default Sportsman 500 Ho
2003 model
Started it this morning and the speedo thinks its a tach and every time you put it in reverse it quits. I can start in neutral and hold the override and be ok.. Any Ideas?
Update: If you unplug the speedo sensor wire, the speedometer stops bouncing and the reverse problem goes away. The speedo sensor has been removed and cleaned with no change. The speedometer will start bouncing with just the key on and wierd display where mileage would be with the wrench icon blinking
Thanks,
Steve
Old May 26, 2006 | 09:16 AM
20045SP500HO's Avatar
bad battery or bad circuit break under the hood.
Old May 26, 2006 | 01:40 PM
dmach8's Avatar
Battery check good .
Old May 26, 2006 | 04:46 PM
BdweiserRacing8's Avatar
Default Sportsman 500 Ho Reverse quitting
My Speedo on my sportsman was messed up as well for a while. When i was doing about 50mph, it would jump way down really fast, and jump back up. I thought there was something messed up with my speed-o-meter, but i took my right front wheel off and washed near the sensor really good and i have no problems now.
Old May 26, 2006 | 04:55 PM
dmach8's Avatar
I have taken the sensor out and cleaned everything.. I guess it could be the sensor and the dealer thought the cluster because of the reverse issue.
What's really strange turn the key on and when your mileage shows, the needle bounces, the tenths increase and there is some weird display, looks like a s then the rest is strange..
I know there is a way to test the speed sensor to narrow things down, will have to find out again how to do it.
Thanks Steve
Old May 27, 2006 | 12:34 AM
Default Sportsman 500 Reverse and speedometer problem
Well, if you cant fix it, it looks like you will have to buy another one. Here is the site for one that i just found...http://cgi.ebay.com/ebaymotors/NEW-P...QQcmdZViewItem
Old May 27, 2006 | 12:45 PM
dmach8's Avatar
Default Resolved:Sportsman 500 Reverse and speedometer problem
Replace the Hall effect speed sensor and cured the problem if anyone else has this issue..
Thanks for the replies,
Steve
Old May 28, 2006 | 03:47 AM
anytime bro
Old May 28, 2006 | 03:53 AM
My email is chilichomper@hotmail.com if you have anymore questions. I may be able to help you out since i have the same year model and make as you.
Old May 28, 2006 | 01:04 PM
dmach8's Avatar
Thanks
Reactant
Mar 30, 2022 02:08 AM
Captjay
Jul 23, 2015 12:33 PM
steveo612
Jul 11, 2015 08:35 AM
Scottma518
Jul 10, 2015 12:42 AM
bikedad3
Jul 2, 2015 02:15 AM
