Couple of LT80 Carb Questions
Old Jul 12, 2006 | 07:49 PM
DocZoom's Avatar
Default Couple of LT80 Carb Questions
Q1, How do I tell the model year on an LT80? I have no idea how old mine is.
Q2, I ordered a Keyster Carb kit for the LT80. It is labeled 1987-1995. Are there any changes from 1995 on, that would make this kit problematic on a newer machine?
Thanks in advance,
Dave
Old Jul 13, 2006 | 11:13 AM
LT80's Avatar
LT80 Expert
There is a letter in the VIN # that means the year. That's all I know about that.
The carbs are all the same.
Old Jul 13, 2006 | 08:07 PM
DocZoom's Avatar
Thanks,
I hope it still runs when I'm done.
I'm getting a lot of 'hydro lock' or whatever so I blame the carb for now.
Old Jul 14, 2006 | 12:11 PM
LT80's Avatar
LT80 Expert
"hydro lock"
Please explain. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 15, 2006 | 10:57 AM
DocZoom's Avatar
For lack of the correct term I use Hydrolock. My cylander is full of fuel and the piston is on the way up and cannot roll over. If I remove the plug and roll it over then a whole bunch of fuel will shoot out. Then I put the plug back in and it might start. I am rebuilding the carb now and hopefully this fixes it.
I am also going to try to remove the oil injection and go to 32:1 mix. Since all my other equipment runns at 50:1 and I buy various 50:1 oils, can I just run the mixed gas at that ratio? It is just brand name John Deer and Toro 50:1 oil.
Old Jul 15, 2006 | 01:52 PM
flojo's Avatar
mine is doing the samething, check your petcock to make sure it is turnig off the gas flow.
Old Jul 15, 2006 | 03:40 PM
DocZoom's Avatar
Ok, I completely rebuilt the carb and it starts perfect. I seem to have lost a little bit of power and top end but I will keep playing with the throttle cable maybe that will fix it.
There only seems to be one screw to adjust anything, is that correct?
One thing I am really confused about (and probably hooked up wrong) is all those tubes.
-I am sure I have the oil-in correct so that one is OK.
-I have the fuel-in going to the lower right side.
-I have the other line that goes from the fuel shut off pluged in above the fuel in.
-What is that other one at the top right side of the carb?
Does a tube go on the bottom of the float tank? It has a drain so I'm guessing it just drains out.
What are the two other open tubes that go toward the back?
Sorry for all the questions I am a complete amature.
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
yagerzzz
Jun 24, 2015 07:45 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
DOAinNY
Jun 11, 2015 10:34 PM
Nowinsky94
May 27, 2015 07:29 PM
