Update on Warrior acc. problem
Old Nov 27, 2000 | 10:32 PM
carterca's Avatar
OK, I tried taking the carb a part and cleaning it, along with the acclerator pump. Everything seems to be in good working order. I've tried all the eleterical ideas and everything seems perfect.
But yet the Warrior still dies when you punch the throttle. Tommorrw I'll be picking up two larger (43 & 43.5)pilot jets to give that a try.
I talked to the Yamaha dealer and they say that the problem is common to all 4 strokes, yet all the Honda's don't do it.
Once the revs are up, you can punch the throttle no problem. Just when its idling and you hit it.
Any ideas?
cr
Old Nov 27, 2000 | 11:05 PM
drocawar2001's Avatar
If you don't mind when you find out the problem let me know. I have the same problem.
Old Nov 30, 2000 | 06:09 PM
macgiver's Avatar
i here thats a problem on the wolverine and warrior uptil 1995, after that they changed the carb. my 95 wolverine dose the same thing.
Old Nov 30, 2000 | 07:43 PM
Labs's Avatar
I have a wolverine 2000 that does not have that problem, but a friend of mine has a 95 wolverine and it has that problem. I know they changed the carb they may have also done something with the cdi box. Hope this helps.
Old Nov 30, 2000 | 11:51 PM
did's Avatar
did
It needs a bigger pilot jet
Old Nov 30, 2000 | 11:54 PM
PC_350_Warrior's Avatar
Well, if you're sitting at idle and you punch the throttle all the way open...most engines are going to bog down or die...just doesnt have enough RPM's to keep it from flooding.
Old Dec 1, 2000 | 10:40 AM
quadcrazy's Avatar
My warrior has never done that. Your Yamaha dealer is pulling the wool over your eyes.
Old Dec 1, 2000 | 12:38 PM
Mr45auto's Avatar
Okay, here's your likely problem. The accelerator pump is not contacting the arm that actuates it. Pull the plastic cover off and look at it when you open up the throttle it takes a bit of travel to engage the pump shaft. If you lengthen the shaft by putting a cap (made from the screw on/off piece on the top of a spark plug where the wire contacts find a small screw to insert partly to fill the hole or it will slide over the shaft.) This will effectively lengthen the shaft making your accelerator pump work far more efficiently. I did this to my Warrior and the hesitation disappeared. Simply the accelerator pump shaft isnt as long as it should be. Just look and see for yourself.
Old Dec 1, 2000 | 01:32 PM
thejerm14's Avatar
My warrior had the same problem when it got hot. i had to change the spark plug. my dealer told me that if you have an old enough spark plug then when it gets hot it will stop working. so try getting a new sparkplug.
Old Dec 1, 2000 | 01:42 PM
carterca's Avatar
OK people I pretty much solved the problem. I changed the pilot jet (45) and moved the clip on the needle down a notch, effectively moving the needle up. Just to let you know I tried the accleratior pump mod and it didn't work.
cr
Reactant
Mar 30, 2022 02:08 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
