This is on the 2005 Trail Blazer
Old Sep 23, 2006 | 03:35 AM
jmcadres's Avatar
Default This is on the 2005 Trail Blazer
Can someone tell me what this drain is? It's in the center of this picture. Picture taken from underneath engine with skid plate removed.
You can see the black drop of oil (or oil-gas mix) coming out of the hole. I've been tryinng to find the source of an oil leak. I thought that the screw that was in this hole was the source of the leak so I tightened the screw and the thread broke off inside the hole.
Is there anything I can do? I think I stripped the threads inside the hole.
Old Sep 23, 2006 | 08:50 AM
quadsport230's Avatar
i dont know what oart this is but at auto part stores they have oversized self tapping plugs, i used one on my QS 230 and it works fine
Old Sep 23, 2006 | 09:43 AM
BGRDTRUK's Avatar
From the picture it looks like a drain plug...there are two one for the motor and one for the starter.(hard to tell which one it is)
The bolt has a hole drilled from the threaded tip to where the threads stop and a second hole across the bolt to alow it to drain without takking the bolt completely out.
That's why it broke so easy (weaker than normal bolt)
Use an "easy out" to take out the threads that are left in the hole and replace with a new one.
try to reuse the alum washer from the first bolt.(acts as a seal)
txpedsrt1
Feb 3, 2017 08:07 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Gnuters
Jul 19, 2015 10:03 AM
tporath
Jul 11, 2015 12:31 PM
Shifts
Jul 3, 2015 07:59 AM
