suzuki lt80 need some help
Old Dec 24, 2006 | 03:39 AM
rhino1973's Avatar
Default suzuki lt80 need some help
i bought a suzuki lt80 for my kids for xmas.when i bought it it ran great.i got it home and relized the exhaust and the side case were the clutch is was filling up with gas.i pulled off the gas line and could not get the gas to shut off.the pidcock has three settings primary on and reserve.which one is off. can anyone tell me what is causing this and how to fix the problem.i am trying to find out the problem before xmas so they can ride their new present.it is a 1987 lt80.please help.
Old Dec 24, 2006 | 10:14 AM
LT80's Avatar
LT80 Expert
Welcome to the forums. [img]i/expressions/face-icon-small-smile.gif[/img]
prime~fuel will run all the time.
On~is off when the motor is not turning.
The petcock is vaccum operated. You should have it in the run position.
Other than that, a good carb cleaning may be in order. There could be a spec of crud holding the float needle open (altho it's doubtful). Remove both jets and the brass seat for the needle and clean.
Old Dec 24, 2006 | 10:16 AM
elroy1's Avatar
Was the gas leaking externally? If you don't see any leaks from the outside, then their is a good chance that it is leaking internally. If so then your float valve may not be closing in side the carb. Thus allowing the carb to over fill which would then begin filling the crankcases. If the left side crank seal was bad this would then let the filling crankcases leak the gas into the clutch area. What about the vent lines/drain on the carb? Are they wet or plugged up? Have you had this machine running yet or have you seen/heard it run?
Old Dec 24, 2006 | 12:18 PM
rhino1973's Avatar
thank you for the info.i turned the pidcock to primary when i shut it off so this all makes sense.the bike ran like a top when i bought it.pretty fast little bike my 4 and 6 year old girls are going to luv it.what is the primary setting used for.never seen a bike with no off.well i am going to go see if the problem is fixed, thank you
Old Dec 24, 2006 | 02:55 PM
LT80's Avatar
LT80 Expert
Prime is there for when it's been sitting or the carb has been cleaned and the bowl is empty.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 24, 2006 | 04:58 PM
rhino1973's Avatar
how does a guy go about changing the oil on these lt 80s.i can`t find the dipstick or the oil drain bolt.i found one in the very back of the machine under the skid plate.is this the drain bolt and were do you fill the oil from.i am going to buy a manual but would like to drain the oil before i let my kids tear up the dirt.
Old Dec 25, 2006 | 02:53 PM
LT80's Avatar
LT80 Expert
Yes, On the bottom in the back is where you drain the tranny oil.
The bolt on top is where you fill it. There is a bolt beside the front sprocket, that's the weep hole. Remove the bolt and fill tilll oil comes out.
10-40 is fine. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 25, 2006 | 10:29 PM
rhino1973's Avatar
thanks lt80 you have been a lot of help.my girls loved that little quad.i appreciate all the help.hope yoe had a very merry xmas.i sure did.thanks again.
ryan
VABrute
Jan 6, 2016 07:39 PM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Sep 1, 2015 11:59 PM
