This 800 heat shield is different.....
Old Apr 7, 2007 | 01:50 AM
Instigater's Avatar
Default This 800 heat shield is different.....
....than the stock pipe that I had my 800 Sportsman. I bought a 800 header and exhaust shield kit for the MV and noticed some differences. My 800 sportsman was the boring individual pieces that resembled something like this. Now This thing looks very nice and should keep the heat away from the plastics, espescially with the black satin ceramic coating I had done to the header. I thought that I would share this info. The heat shield kit(shield and bolts) is P/N 2876048 and I paid $42 for it. If you want to find your own bolts, you could order just the shield with P/N 5250299-385(silver). The smaller shield in the pic above isn't in the kit, that is P/N 5244014 and it was another $4! Basically I am happy, I was worried about a little extra heat, but the ceramic should help that. Now with this shield, I should tape my water bottles to the pipe for a water cooler! Ok, I am just jokin'. I should be good though![img]i/expressions/face-icon-small-cool.gif[/img]
Old Apr 7, 2007 | 03:16 AM
outside2day's Avatar
Instigater-How close are you with that MV being trail ready? Header coated? Axles back in? Bet you are ready!
Old Apr 7, 2007 | 06:50 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
so your saying this wasnt on your 800 when you had it. you had smaller heat sheilds. ive been doing some reading where a guy had his pipe coated and didnt seem to help the extra heat that he feels on his leg. says that the 30 or what ever degrees didnt seem very noticable, makes me wonder if its worth it so let us know big guy when its done and running if you actually feel the differnce.
Old Apr 7, 2007 | 02:48 PM
Instigater's Avatar
I just hung up with my powder coater about 10 mins ago. The pipe is done, I will pick it up Tuesday! Axles are in, plastics are off, (waiting for the pipe). I am ready, quad is not, [img]i/expressions/face-icon-small-frown.gif[/img]. We will both be ready for the over nighter that is planned for April 15![img]i/expressions/face-icon-small-cool.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 7, 2007 | 03:17 PM
patrolman800's Avatar
keep us updated with the ceramic coating what it does for the heat problems just found a guy locally to do mine dont want to do it if it doesn't help thanks
Old Apr 7, 2007 | 10:59 PM
trailbound's Avatar
Setting up 800s at the dealership, I noticed newer/larger heat shields on the later 06 models and 07 delux's. Will probably order the kit for myself.
Old Apr 8, 2007 | 12:06 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
hey trail how long are they on the later models?
Old Apr 8, 2007 | 12:14 AM
these heat shields came on my 06 they dont cut the cheese or by far solve the problem have the same heat problems on my 05, love the machine but these problems are really stupid.
Old Apr 8, 2007 | 11:32 AM
trailbound's Avatar
stendori, I cant remember if they are longer, but they are wider and have a sort of flared look in the front to maby direct air in as they move and help to cool? Just a thought. I'll be getting them and let you know If they fit on my 06 stock pips.
Old Apr 8, 2007 | 11:08 PM
Totun's Avatar
Feb 06 is when they upgraded the shields. In 07 they changed the 800 header to a two piece pipe. You will notice a bolt hole on the side of the shield at the back for this model. I recommend ceramic coating the shields as well and take some time to fit it, (drill and file if you have to) leaving about 1/4" of gap between it and the pipe. The washers that come with it are also coated to prevent heat from transferring from the pipe to the shield. I want to point out another important part of the shield installation is the re-shaping of the shifter rod. This is also important to gain additional clearance and hold the plastic away from the shield. This is complicated because both ends have "rod eyes" in them. When you bow it outward around the shield it wants to sag. It falls in front of the rear plastic when in high and then binds when you try and get it into park. It?s not a quick thing to adjust but there is a sweet spot. The instructions won?t tell you this but keep the shifter rod underneath the rear plastic when in high.
In 07 they changed the shifter rod to overcome this. May be an option worth studying....
Totun
Jeff Roper
Feb 1, 2022 11:48 AM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jeff Roper
Sep 21, 2015 02:11 PM
poutlaw525
Sep 9, 2015 03:19 AM
