2003 Polaris Sportsman 700 4x4
Old Sep 23, 2007 | 06:07 PM
9bcomput's Avatar
Default 2003 Polaris Sportsman 700 4x4
I've noticed some frontend left and right shaft movement on the main shafts to the front end...Is this bearings?
Old Sep 23, 2007 | 06:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is it alot of in and out play on the drive shaft, if that the shaft your refering too?
Old Sep 23, 2007 | 08:04 PM
9bcomput's Avatar
No not on the drive shaft...but where the right and left wheels connect. I f you reach onto each wheel shaft you can move it up and down within the gear box...
Old Sep 24, 2007 | 03:30 AM
dosceola's Avatar
The CVs are whatu are refering to right? rubber boots on both ends. If so they should be tight into front diff flush mounted to case. They will wiggle alittle like barely any movement in any direction.if I'm on right part here theres a snap ring that holds into front diff on CV shaft they have teeth,grooves. that interlock so movement should be minimal,but they do wiggle
Old Sep 24, 2007 | 06:43 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there shouldnt be very much movement where the cv's go into the front end. they do move in and out but not up and in down.
Old Sep 24, 2007 | 01:09 PM
dosceola's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
there shouldnt be very much movement where the cv's go into the front end. they do move in and out but not up and in down.</end quote></div>
They do jiggle around more then in and out.If u put your hand around center shaft and pull, it will wiggle around.I was trying to describe things that happen so he might better understand. cause I'm not sure we are talking about same part. It is minimal movement in shaft coming out of front diff.very minimal. some folks see things diffrently if thats moving part u are wondering about.If it's moving in and out I would be worried about locking ring being broke on CV
Old Sep 24, 2007 | 06:28 PM
KING4X4's Avatar
i have an 03 700 to i also have a 1" litf and my u-jionts move aloat and are nosey at times
Old Sep 24, 2007 | 08:39 PM
9bcomput's Avatar
Im in southern maine...but mainely 4 wheel downeast Maine.
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Gtsordo
Jul 13, 2015 10:38 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
